1 Reply Latest reply on Jul 12, 2010 5:02 AM by Ned Murphy
    How to set criteria to Play/Pause buttons
    toastiesmonster
      How to set conditional criteria to Play/Pause buttons?
      i.e. to pause the animation only if the animation is playing; and to  play the animation again only if the animation is paused. thanks.
      on(release) {
      play();
      on(release) {
      stop();
        • 1. Re: How to set criteria to Play/Pause buttons
          Here's where that isStopped variable you had in your other posting could be handy if the intention is to have one button do both...
          var isStopped:Boolean  = false; // assuming it is playing at the start
          on(release){
               if(isStopped){
                    isStopped = false;
                    play();
               } else {
                    isStopped = true;
                    stop();
          But if you have separate buttons for Play and Pause, what you showed already would be sufficient when you match the two code bits to the correct buttons.
