5 Replies Latest reply on Aug 20, 2007 1:35 AM by Newsgroup_User
    creating template component
    Level 7
      I am trying to create a template component that can be used elsewhere in
      an mxml file.
      I thought his would work for the component definition:
      <mx:Canvas xmlns:mx=" http://www.adobe.com/2006/mxml"
      width="{frameworkWidth}"
      height="{frameworkHeight}"
      x="{frameworkX}"
      y="{frameworkY}"
      creationComplete="init()">
      <mx:Script>
      <![CDATA[
      //width and height of the component
      [Bindable]
      public var frameworkWidth:int = 800;
      [Bindable]
      public var frameworkHeight:int = 600;
      //x and y positions of the framework
      [Bindable]
      public var frameworkX:int = 0;
      [Bindable]
      public var frameworkY:int = 0;
      import mx.core.UIComponent;
      import mx.containers.ViewStack;
      [ArrayElementType("mx.core.UIComponent")]
      public var frameworkContent:Array;
      private function init():void
      //add the viewstack 'framework'
      var framework:ViewStack = new ViewStack();
      framework.percentHeight = 100;
      framework.percentWidth = 100;
      this.addChild(framework);
      //loop through the array and add content to the framework as set in
      the array of UI components
      for(var i : int =0 ; i < this.frameworkContent.length; i++)
      framework.addChild(this.frameworkContent );
      </mx:Script>
      </mx:Canvas>
      with the following being the main mxml file for testing currently:
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml"
      xmlns:eLearning ="components.*" backgroundColor="#FFFFFF"
      layout="absolute" width="800" height="600">
      <eLearning:Framework frameworkWidth="800" frameworkHeight="600">
      <mx:Canvas width="100%" height="100%">
      <mx:Image source="assets/menu.jpg" x="40" y="50"/>
      </mx:Canvas>
      <mx:Canvas>
      <mx:Image source="assets/exit.jpg" x="40" y="100"/>
      </mx:Canvas>
      </eLearning:Framework>
      </mx:Application>
      But this doesn't seem to be working. Can someone point me at what I am
      doing wrong please?
      Mark
        • 1. Re: creating template component
          USawIt
          Mark,
          I changed the code of your component in two places (wrapped a type'ing of DisplayObject in the for loop in the init function and set your declaration of frameworkContent = new Array(), and the UI loaded without compile-time or runtime errors.
          Hope this helps,
          Mike Givens :-)
          <mx:Canvas xmlns:mx=" http://www.adobe.com/2006/mxml" width="{frameworkWidth}"
          x="{frameworkX}"
          y="{frameworkY}"
          <mx:Script>
          <![CDATA[
          [Bindable] public var frameworkWidth:int = 800;
          [Bindable] public var frameworkHeight:int = 600;
          [Bindable] public var frameworkX:int = 0;
          [Bindable] public var frameworkY:int = 0;
          [ArrayElementType("mx.core.UIComponent")] public var frameworkContent:Array = new Array();
          //loop through the array and add content to the framework as set in the array of UI components
          for(var i:int=0; i < this.frameworkContent.length; i++)
          framework.addChild(DisplayObject(this.frameworkContent));
          </mx:Script>
          </mx:Canvas>
          • 2. Re: creating template component
            Level 7
            USawIt wrote:
            > Mark,
            > runtime errors.
            > Hope this helps,
            > Mike Givens :-)
            > x="{frameworkX}"
            > y="{frameworkY}"
            > <mx:Script>
            > <![CDATA[
            > </mx:Script>
            > </mx:Canvas>
            That does help a lot thanks, but now I realise it doesn't do what I
            intended. I am trying to set up a ViewStack and each element in the
            main app ending up as a child of the ViewStack so:
            <mx:Text text="Hello world"/>
            </mx:Canvas>
            <mx:Canvas>
            </mx:Canvas>
            would make 2 children on the ViewStack as there are 2 Canvas components.
            I thought my approach would work. Any ideas?
            Also, how can I then access the ViewStack (framework). I wanted to add
            some buttons to the component for navigation but I don't seem to be able
            to reference the ViewStack. I did expect to be able to call
            framework.selectedIndex++ etc, but that doesn't seem to be in scope either??
            Thanks for any help
            Mark
            • 3. Re: creating template component
              Level 7
              Mark Tomlinson wrote:
              > USawIt wrote:
              >> Mark,
              >> Hope this helps,
              >> Mike Givens :-)
              >> x="{frameworkX}"
              >> y="{frameworkY}"
              >> <mx:Script>
              >> <![CDATA[
              >> </mx:Script>
              >> </mx:Canvas>
              > </mx:Canvas>
              > <mx:Canvas>
              > </mx:Canvas>
              > either??
              > Thanks for any help
              > Mark
              and in fact adding this to the component after the script:
              <mx:Button click="doNavigate('Next')" x="723" y="363"/>
              Throws another error?? Error: Multiple sets of visual children have
              been specified for this component (component definition and component
              instance).
              Now I AM confused!
              Mark
              • 5. Re: creating template component
                Level 7
                peterent wrote:
                > This might be what you want:
                > http://weblogs.macromedia.com/pent/archives/2006/03/component_templ.cfm
                Yes, that looks very similar to what I am trying to do thanks, but I
                can't see how to customise this so that I can add multiple 'pages'
                (children) to a ViewStack.
                Mark
