5 Replies Latest reply on Jul 13, 2010 4:40 AM by Ned Murphy
    Button event not working correctly
    bradt8
      I'm creating a project with a number of different sections. I've created a index menu with invisible buttons on that takes you to the different sections. This works fine. In each section I wonted a means to get back to this index, so created a index button that is present throughout each section. I've put the event handler in the actions layer on the same frame that the button instance is on (frame 15).
      idex_bt.addEventListener(MouseEvent.CLICK, indexBack);
      function indexBack(e:MouseEvent):void{
      gotoAndStop(10);
      The problem is that the button only works at this point if you move to any other section it does not. I can see no reason for this. The invisible buttons that jump you to each section work an all the frames they are present on, but the index button does not.
      I feel like I'm missing something very simple, any ideas?
