3 Replies Latest reply on Jul 13, 2010 11:21 PM by aditi_bk
    Loader not linking to the external swf being loaded
    aditi_bk Level 1
      I am trying to make this website, which has  separate files for different screen resolutions. I am using a first.swf  file to load the right file, depending on the screen resolution, it goes to a different frame for diff resolutions. There I have placed a loadMovie function.
      The code for the loader follows the loadMovie call. loadingbar is a movieclip on screen, which presently does nothing.
      _root.loadMovie("filename.swf", mcholder);
      loadingbar.onEnterFrame = function() {
      kBytesLoaded = this._parent.mcholder.getBytesLoaded() / 1024;
      kBytesTotal = this._parent.mcholder.getBytesTotal() / 1024;
      percentage = Math.round(kBytesLoaded / kBytesTotal * 100);
      txt1.text = percentage;
      if (percentage == 100) {
      delete this.onEnterFrame;
      This was displaying nothing, so I replaced the _root.loadMovie with mcholder.loadMovie("filename.swf"). This is not working either, the screen flashes
      for one second and then  disappears. I put a stop(); before the code, and the screen remained,  but the movie still did not load.
      I txt1.text shows 100. meaning percentage did reach hundred, but I am guessing that is for first.swf, and not for the file which is being loaded. I am still
      learning the ropes and would appreciate it if someone could tell me what I am doing wrong. Any help will be greatly appreciated.
        • 1. Re: Loader not linking to the external swf being loaded
          aditi_bk Level 1
          I have now changed the code to
          mcholder.loadMovie("filename.swf");
          loadmc.onEnterFrame = function () {
          percent = Math.floor((this._parent.mcholder.getBytesLoaded()/ this._parent.mcholder.getBytesTotal())*100);
          prcnt.text = percent+ "%";
          if (percent == 100){
          prcnt._alpha =0;
          loadmc._alpha = 0;
          Now it shows nothing at all. the 'prcnt' textbox displays nothing. It only shows the loadmc movieclip, which is also not playing. What am I doing wrong?? Some one help...!!!!!
          • 2. Re: Loader not linking to the external swf being loaded
            You should look into using the MovieClipLoader.loadClip method instead of loadMovie... it's made for information-based loading.  Search Google using "AS2 MovieClipLoader tutorial" and you should find some helpful tutorials.
            • 3. Re: Loader not linking to the external swf being loaded
              aditi_bk Level 1
              Hi Ned,
              Thanks for the suggestion. I looked up MovieClipLoader tutorials and finally came up with the code:
              var myMCL:MovieClipLoader = new MovieClipLoader();
              var loadListener:Object = new Object();
              myMCL.addListener(loadListener);
              loadListener.onLoadProgress = function(target_mc:MovieClip, bytesLoaded:Number, bytesTotal:Number):Void
                  var perc:Number = (bytesLoaded / bytesTotal) * 100;
                  prcnt.text = perc + " %";
              loadListener.onLoadInit = function(target_mc:MovieClip)
                  trace( target_mc + " finished loading so display on screen now. " );
                  prcnt.text = "init";
              loadListener.onLoadError = function(target_mc:MovieClip, errorCode:String, httpStatus:Number)
                  trace( "error loading image : errorCode : " + errorCode );
              loadListener.onLoadStart = function(target_mc:MovieClip)
                  trace( target_mc + " start loading. maybe you want to do something here? " );
                  prcnt.text = "onstart";
              myMCL.loadClip("filename.swf", mcholder);  //mcholder is the movie clip holder placed on stage manually
              The problem here is that the file does not move beyond
              _level0.mcholder start loading. maybe you want to do something here?
              Why is this happening? The code is directly from the tutorial. I have included all event functions, in case they are something like abstract functions, I don't know if this is required or not. I know I must be being a pain, but I can't figure out what is wrong with the code, seems simple enough to me. I am sure I am missing some basic point. Any help will be greatly appreciated...
