4 Replies Latest reply on Jul 15, 2010 9:29 AM by AgamSarup
    SDK_Exporter_params.cpp in SDK Exporter plugin for premiere pro cs4
    AgamSarup
      This question is regarding the code in
      exSDKGenerateDefaultParams(exportStdParms                *stdParms,
                                               exGenerateDefaultParamRec    *generateDefaultParamRec) function
      The below function is called in the above function's code
      exportInfoSuite->GetExportSourceInfo(    exporterPluginID,
                                                      kExportInfo_VideoFrameRate,
                                                      &seqFrameRate);
      to get info for videoframerate in seqFrameRate
      Then seqFrameRate.mFloat64 is compared with different values in the code segment
      if(timeSuite)
           timeSuite->GetTicksPerSecond (&ticksPerSecond);
           if (seqFrameRate.mFloat64 > 29.97f &&
                  seqFrameRate.mFloat64 < 29.98f ||
                  seqFrameRate.mFloat64 < 0.1f ||
                  seqFrameRate.mFloat64 > 60.0f) // Strange values fall into this case
                  timeSuite->GetTicksPerVideoFrame(kVideoFrameRate_NTSC, &seqFrameRateTicks);
      for assigning the appropriate value to seqFrameRateTicks
      The problem i m facing is that the value of seqFrameRate.mFloat64
      is coming out to be zero(why?).
      Also, since the type of ticksPerSecond and seqFrameRateTicks
      is PrTime(which is a 64 bit int), i want to know what will be the best way
      to convert them into other 32 bit values(int, float etc).
      Thank You
      Agam
        • 1. Re: SDK_Exporter_params.cpp in SDK Exporter plugin for premiere pro cs4
          Zac Lam Adobe Employee
          Hi Agam,
          This code in the CS4 SDK was written for the initial 4.0 release, where GetExportSourceInfo(kExportInfo_VideoFrameRate) originally returned a float value.  In 4.0.1, this was changed (to be simpler for developers) to return a PrTime value.  So in the CS5 SDK release, the code now looks like this:
              exporterPluginID,
            &seqFrameRate);
          frameRateValues.value.timeValue = seqFrameRate.mInt64;
          So it now uses the mInt64 member of the union, because PrTime is a 64-bit int.
          To convert PrTime to a float, the SDK Guide, chapter 3, section on Time, reads: "When a frame rate is represented as a PrTime, the frame rate is the number of ticks in a frame duration.  The current number of ticks per second must be retrieved using the  callback in the Time Suite."  So just divide the PrTime value by the ticks per second returned by GetTicksPerSecond().
          Cheers
          • 2. Re: SDK_Exporter_params.cpp in SDK Exporter plugin for premiere pro cs4
            AgamSarup Level 1
            Hi Zac
            Thanks for ur reply.
            I just want to confirm what i have understood.
            timeSuite->GetTicksPerSecond (&ticksPerSecond); // gives ticks/sec
                                                            &seqFrameRate);  // gives ticks/frame
            Instead of using seqFrameRate.mFloat64, i should use seqFrameRate.mInt64
            So both, ticksPerSecond and seqFrameRate.mInt64 are 64 bit int which are
            ticks/sec and ticks/frame respectively.
            Now, i can get fps(frames per second) as following
            seqFrameRateTicks = (ticks/sec)/(ticks/frame) = ticksPerSecond/seqFrameRate.mInt64
            which is a 64 bit int(PrTime).
            Also, if seqFrameRate.mInt64 is required, why is seqFrameRate.mFloat64 still used in the code?
            Agam
            • 3. Re: SDK_Exporter_params.cpp in SDK Exporter plugin for premiere pro cs4
              Hi Agam,
              Yes, your summary is correct.
              The CS4 SDK sample code uses mFloat64 because it was written during the development of CS4.  At that time, I requested that we change the time value returned by GetExportSourceInfo(kExportInfo_VideoFrameRate) to be a PrTime rather than a float, since it simplifies the code in most cases.  This change to GetExportSourceInfo() wasn't made until 4.0.1, and I didn't update the SDK sample code until after releasing the CS4 SDK.
              So go ahead and use the mInt64 member, and make sure the plug-in is running in 4.0.1 or later, not 4.0.  You can check this by looking in exportStdParms.interfaceVer.  If that value is prExportVersion100, that means it is PPro 4.0.  On exSelStartup, you could just display a message that the user should update to 4.0.1 or later.
              Regards,
              Zac
              • 4. Re: SDK_Exporter_params.cpp in SDK Exporter plugin for premiere pro cs4
                AgamSarup Level 1
                Hi Zac,
                I did use that and it worked.
                Thanks again.
                Agam
