2 Replies Latest reply on Jul 14, 2010 3:52 AM by KevMull
    CurrencyFormatter In Datagrid Shows Zero For Values less than 1.00
    KevMull Level 1
      I'm using the CurrencyFormatter in my datagrid but for some reason values less than 1.00 (i.e. 0.52, 0.75 etc) show as £0.00.
      All other values are fine.
      Here is my ciode...
      <mx:CurrencyFormatter id="gbpFormat" alignSymbol="left" precision="2" currencySymbol="£" rounding="none"  useNegativeSign="false" />
      <mx:DataGridColumn headerText="Unit Price" dataField="unitPrice" textAlign="right"
                               labelFunction="price_labelFunc"  sortCompareFunction="price_sortCompareFunc"  />
      protected function price_labelFunc(item:Object, column:DataGridColumn):String
                  return gbpFormat.format(item.unitPrice);
      The data is via an XML which typically looks this...
      <unitPrice>0.52</unitPrice>
      Using Flex 3 (sdk 3.6)
      Many Thanks
        • 1. Re: CurrencyFormatter In Datagrid Shows Zero For Values less than 1.00
          rtalton Level 4
          I had the same issue with your code until I used an XMLListCollection as the dataprovider.
          Here is my full sample code:
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
              <![CDATA[
                  private function price_labelFunc(item:Object, column:DataGridColumn):String{
                      trace(item);
                      return gbpFormat.format(item);
          </mx:Script>
          <mx:XML id="xmlData">
              <prices>
                  <unitPrice>1.52</unitPrice>
                  <unitPrice>0.55</unitPrice>
                  <unitPrice>0.75</unitPrice>
              </prices>
          </mx:XML>
          <mx:XMLListCollection id="XMLListData"
                      source="{xmlData.unitPrice}" />
          <mx:DataGrid dataProvider="{XMLListData}"
              <mx:columns>
                      textAlign="right"
                      labelFunction="price_labelFunc"/>
              </mx:columns>
          </mx:DataGrid>
              alignSymbol="left"
              precision="2"
              currencySymbol="£"
              rounding="none"
          </mx:Application>
          • 2. Re: CurrencyFormatter In Datagrid Shows Zero For Values less than 1.00
            KevMull Level 1
            Many Thanks
            The proble was in my resultHander I was declaring unitPrice as a Number wher I should have left it blank..
            storeProductItem1.unitPrice = event.result.ajaxResponse.objectDetails.storeProductItem.unitPrice ;
            WAS (incorrectly)
            storeProductItem1.unitPrice = event.result.ajaxResponse.objectDetails.storeProductItem.unitPrice as Number ;
