1 Reply Latest reply on Jul 13, 2010 5:57 AM by Dileep_NR
    Web Service Authentication in Coldfusion
    joshi_10in Level 1
      Hi
      I am trying to perform Web Service Authentication in Coldfusion. The webservice is written using a CFC.
      It is a normal CFC, and I am generating the Web Service URL as test.cfc?WSDL
      Is there a way that I can authenticate a web service method using SOAP headers ?
      There is a code mechanism in ASP.NET, where we can beautify the web service with codes  that will ask for a username and password for
      accessing a method of a web service.
      I am testing the web services using SOAP Sonar, it is a very good tool. When testing, if there is an authentication mechanism in a web service,
      then it will prompt you to enter the user name and password. At the moment, I have included two fields (username and password) for each
      method to do the custom authentication against a login info stored in Application.cfm.
      I found a way using WSSJ4 from Apache, but it looked too complex and not very straight forward to acheive it.
      Please if anyone have found a solution, please let me know.
      Thank you in advance..
      Josh Thomas
        • 1. Re: Web Service Authentication in Coldfusion
          Dileep_NR Level 2
          Please try the follwoing code set
          /*REMOTE METHOD
          soaptest.cfc
          <cffunction name="addNumbers" access="remote" returntype="test" output="false">
                  <cfargument name="firstNumber" type="string" required="true"/>
                  <cfargument name="secondNumber" type="string" required="true"/>
                  <cfset retunVal="NO">
                  <cfset username=0>
                  <cfif isSOAPRequest()>
                          <cfset retunVal="YES">
                          <cfset username = getSOAPRequestHeader("http://localhost/testsoap/", "setInit")>
                           <cfset retunVal= arguments.firstNumber + arguments.secondNumber & username>
                  </cfif>
                  <cfreturn retunVal />
              </cffunction>
          /*calling remote method
          index.cfm
          <cfsavecontent variable="soap">
          <?xml version="1.0" encoding="UTF-8"?>
          <soapenv:Envelope
                  xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/
                  xmlns:xsd="http://www.w3.org/2001/XMLSchema"
                  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
                  xmlns="http://localhost/testsoap/">
                  <soapenv:Header>
                  <setInit>1</setInit>
                  </soapenv:Header>
                  <soapenv:Body>
                  <addNumbers soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" >
                  <firstNumber>1000</firstNumber>
                  <secondNumber>10</secondNumber>
                  </addNumbers>
                  </soapenv:Body>
                  </soapenv:Envelope>
          </cfsavecontent>
          <!--- Note that there's no ?wsdl appendage to the url --->
          <cfhttp url="http://localhost/testsoap/soaptest.cfc" method="post">
              <cfhttpparam type="header" name="content-type" value="text/xml">
              <cfhttpparam type="header" name="SOAPAction" value="">
              <cfhttpparam type="header" name="content-length" value="#len(soap)#">
              <cfhttpparam type="header" name="charset" value="utf-8">
              <cfhttpparam type="xml" name="message" value="#trim(soap)#">
          </cfhttp>
