2 Replies Latest reply on May 31, 2011 1:30 AM by Adam_Chojnacki
    Best Practices - Deploying DSC updates
    The Flex Viking Level 1
      FYI, I am using ES1.
      When I want to move all my updates from a DEV instance to a PROD instance, I create an LCA.  I am careful to update the version numbers on all my processes so that when I import the LCA, the updated processes will be imported into PROD.  If the process in the LCA has the same version number as the process on PROD, it won't import.
      I have not been able to figure out how to accomplish the same thing with a DSC.  At this time, I move my components manually from DEV to PROD and I either
      1. Patch an installed component, which will update the component version (look at AdminUI), but does not update the version in the name.  It will still say XYZService:1.0
      2. Remove the old component, install the new component.  This will show the new service name as XYZService:1.1
      The problem with this is
      1. Its a manual process that takes time
      2. if I ever had a need to roll back a component, I can't.  To solve this, I keep a copy of each version of the JAR file I used to install the component.  I can always roll back "manually".  This is completely different than processes of course, which is a simple matter of deactivating the latest version.
      One of my thoughts was to create a 2nd <service/> element in my component.xml, but that seems like a lot of work.  What happens when I am on version 1.12?
      Anyone have any thoughts on best practices in managing components between DEV and PROD instances?
