9 Replies Latest reply on Oct 29, 2010 8:48 PM by Brad Higerd
    How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
    tfi productions 44 Level 1
      #1) Downloaded  the current version of izotope's ozone 4.03b vst,dx, au 3rd party plugin for premiere
      Premiere will see the program because it shows it loading on the initial splash screen
      however, it is not listed as an effect from within the audio mixer
      nor is it available in the effect folders on the lower right of premiere's program window...
      i have contacted izotope about it, yet haven't heard anything
      i have successfully loaded other 3rd party plugins into premiere from trapcode, magic bullet, red giant...
      and the ozone.dll's are copied into the programfiles/adobe/common/cs5/mediacore folder like the pdf documentation for premiere states
      #2)  also, soundbooth doesn't seem to have a way to load 3rd party plugins (vst's, vsti's) like acid pro
      please help
      thanks,
      jeffrey
        • 1. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
          the_wine_snob Level 9
          Jeffery,
          Welcome to the forum.
          Looking on Isotope's site, I could not find anything about Ozone's compatibility with CS5, and also it only shows it for up to Vista, and not Win7
          Also, many VST's will load, but PrPro cannot work with them. I have a few of those, and on the very first loading, PrPro reports that it cannot work with that particular VST. This is a one-time message, and I never see it again. I'm not saying that this is the case with Ozone, but I'd have thought that their compatibility guide would list the PrPro version numbers. Maybe I was looking at the wrong page, and just never found it.
          Now, in the Effects Panel, type "ozone" into the query box, just to make sure that it has not loaded into a folder, where you might not have looked.
          I do not know the program to comment, but perhaps others will.
          • 2. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
            hello,
            thank you for the helpful information
            i never did get that Ppro couldn't work with the ozone
            the Ppro splash screen shows it loading each time i start Ppro
            the search field in the effects box yielded no entries for 'ozone' or 'izotope'
            thanks...
            i guess i'll chalk it up to one vst Ppro doesn't support yet
            it is a phenomenal mastering effects suite
            hastaluego,
            jeffrey
            • 3. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
              Jeffery,
              When you first loaded Ozone, and then launched PrPro, did you get any sort of message? Now, in my case with PrPro 2.0, every time that I would install VST's, that did not work with PrPro, I'd get a message to the effect, "SampleTank2.dll cannot be used by PrPro, but will load." The message was ONLY on the first launch after the VST installation. Those VST's still load, but do not appear in the Effects Panel, as PrPro cannot use them. Each works in other apps., but just not PrPro.
              Good luck, and if you hear from Isotope, please share their response,
              • 4. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
                hello,
                to add more info:
                ozone installs into the x86program files folder
                ozone installs 64bit dlls into the vstplugins folder of the 'program files' (which is the 64bit programs folder)
                don't know if this can account for the glitch that Ppro sees ozone but cannot, like you said, work with it...
                when i hear from ozone i'll post
                thanks again,
                j
                when i used earlier versions of Ppro i would see that one time only message about vsts not being usable
                i never saw it with ozone
                • 5. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
                  hey Bill,
                  i just posted a response
                  i did see that message when i used to use older versions of Premiere
                  i wonder if the problem is because ozone isn't truly 64 bit (if it is installing into the x86programs folder)
                  go figure
                  it is a superb program
                  and to be able to use it from within cs5 (it won't load into AE or soundbooth both who also use vst)
                  would be an excellent addition to the workflow
                  the soundbooth problem is actually weird because it is a 32 bit program:  Soundbooth should see ozone...
                  j
                  Date: Tue, 13 Jul 2010 14:05:19 -0600
                  To: littlejamaicastudios@hotmail.com
                  Subject: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
                  Jeffery,
                  • 6. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
                    A plugin needs to be 64 bits for it to work in CS5.
                    If it install itself in x86 its 32 bits and its a no show.
                    • 7. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
                      hello,
                      i hate to say it but i think you're right
                      ozone did install into the x86 folder
                      with 64bit dlls, but still a no show
                      until ozone gives a definitive answer
                      i'll go with what you said....
                      thanks a  bunch,
                      j
                      • 8. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
                        hey B,
                        finally got the ozone fixed
                        you have to copy the 32bit ozone .dll files
                        from the 32 bit ozone folder
                        into the plugins folder of soundbooth
                        once the dlls are installed
                        soundbooth sees it
                        but only from the effects tab at the top
                        of the soundbooth window
                        so any clip you need to tweak audio on
                        can be right clicked and edited in soundbooth
                        then replaced back into the timeline
                        ozone kills any other mastering plugins out there
                        take it easy,
                        jeffrey
                        Jeffery,
                        • 9. Re: How to get Izotope Ozone 4.03b to work in CS5 Premiere Pro please?
                          Brad Higerd
                          I followed the steps to move the 32-bit Ozone 4.03b .dll files, and Ozone still doesn't work in Soundbooth.
                          Did you do anything else?
                          Bra
