9 Replies Latest reply on Aug 19, 2011 11:08 AM by Brad.White
    problem desecting items in spark list?
    barnetj1
      Hi All,
      Ok i have a spark list and allowMultipleSelects is equal to true.. All i want to do is deselect all the items that user has selected when he/she hits a button.. But this does not happen.. I have tried..
      list.selectedIndex = -1;
      list.selectedIndices = new <int>[-1];
      nothing works, all the values stay the same, as when they were first selected..
        • 1. Re: problem desecting items in spark list?
          barnetj1 Level 1
          Anyone know the answer to this? Is it bug in the spark List component?
          • 2. Re: problem desecting items in spark list?
            UbuntuPenguin Level 4
            Have you tried something like this
            list.selectedItems = null;
                         or
            list.selectedIndices = null;
            It may not like the null value , so you may have to make an empty vector and set the selectedItems/selectedIndices to that.  I don't know how it would look exactly since I haven't used a Vector in Flex 4 , but I'm sure there is some literature around.
            If this post was helpful , please mark it as such.
            Sincerely ,
              Ubu
            • 3. Re: problem desecting items in spark list?
              barnetj1 Level 1
              Pen thanks..
              I have tried this..
              list.selectedIndices = new [-1];
              does not work..
              and these do not work either..
              list.selectedIndex = null;
              • 4. Re: problem desecting items in spark list?
                barnetj1 Level 1
                Sorry this
                should be..
                thanks
                • 5. Re: problem desecting items in spark list?
                  barnetj1 Level 1
                  I also have tried this..
                  list.selectedIndices = new <int>[];
                  and nothing.. the first selected values, are still selected in the spark list on the second time through
                  • 6. Re: problem desecting items in spark list?
                    Peter deHaan Level 4
                    @barnetj1,
                    Can you please file a Spark List bug at http://bugs.adobe.com/flex/ against the Flex SDK (and include a simple test case) and somebody from Adobe can take a closer look.
                    Peter
                    • 7. Re: problem desecting items in spark list?
                      Actually, I'm unable to reproduce the issue with this simplified test case:
                                     xmlns:s="library://ns.adobe.com/flex/spark">
                          <fx:Script>
                              <![CDATA[
                                  import mx.utils.ObjectUtil;
                                  protected function btn_clickHandler(evt:MouseEvent):void {
                                      lst.selectedIndices = new Vector.<int>();
                                      callLater(btn_creationCompleteHandler, [evt]);
                                  protected function btn_creationCompleteHandler(evt:Event):void {
                                      debbie.text = ObjectUtil.toString(lst.selectedIndices);
                          </fx:Script>
                          <s:controlBarContent>
                              <s:Button id="btn"
                                        label="clear selected indices"
                                        creationComplete="btn_creationCompleteHandler(event);"
                                        click="btn_clickHandler(event);" />
                              <s:Label id="sdkVer" initialize="sdkVer.text = mx_internal::VERSION;" />
                              <s:Label text="{Capabilities.version}" fontWeight="bold" />
                          </s:controlBarContent>
                          <s:layout>
                              <s:VerticalLayout paddingLeft="20" paddingRight="20" paddingTop="20" paddingBottom="20" />
                          </s:layout>
                          <s:List id="lst" labelField="fontName" allowMultipleSelection="true" width="200" change="btn_creationCompleteHandler(event);">
                              <s:layout>
                                  <s:VerticalLayout requestedRowCount="10" gap="0" horizontalAlign="contentJustify" />
                              </s:layout>
                              <s:dataProvider>
                                  <s:ArrayList source="{Font.enumerateFonts(true)}" />
                              </s:dataProvider>
                          </s:List>
                          <s:TextArea id="debbie" />
                      </s:Application>
                      Peter
                      • 8. Re: problem desecting items in spark list?
                        MichaelDelaney
                        Try validating the display list after setting the selected index, this will force the list to refresh.
                        list.validateDisplayList();
                        Worked for me ^_^
                        • 9. Re: problem desecting items in spark list?
                          Brad.White Level 1
                          I finally got it working with this:
                          list.validateProperties();
                          Good luck.
