6 Replies Latest reply on Jul 13, 2010 4:37 PM by Colin Brougham
    Workflow for converting NTSC to PAL with Premiere/AME
    Mike Tomei-pAZ4wa Level 1
      Hi everyone,
      After searching the forums, I see that to convert NTSC to PAL for  standard def DVD, most recommend using Canopus Procoder software for the  MPEG2 encoding, or using a hardware based solution.  I don't have the  money for those options, so I was hoping you could clear up something  for me.  Which of these options is best?:
      Option #1:  import the NTSC footage into Premiere and edit on a NTSC  timeline with settings matching the original footage.  Then use Adobe  Media Encoder to encode a PAL format MPEG2 file for the standard def  DVD.
      Option #2:  import the NTSC footage into Premiere and edit on a  timeline set up with PAL resolution and framerate settings, and simply  scale up the NTSC footage to match the larger PAL resolution.  Then use  Adobe Media Encoder to encode a PAL format MPEG2 file for the standard  def DVD.
      Thanks for the help!!
      Mike
      Intel i7-930 2.8GHz
      12 GB RAM
      1 GB VRAM
      Adobe CS 5
