5 Replies Latest reply on Jul 14, 2010 4:06 AM by BhaskerChari
    download file without prompt window in flex?
    Prashant@Mdocs
      how i can download a file from remote server without prompt window(where to save file) in flex.i have already downloaded file from remote server,but during downloading i am getting a prompt window(where to save file).?below is the code which i am using.....................,i want downloaded file is saved to default location on system without prompt window?
      <mx:WindowedApplication
      xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical">
      <mx:Script>
      <![CDATA[
      import mx.controls.Text;
      import mx.controls.Alert;
      Bindable]
      private var fileRef:FileReference = null;
      private function downloadFile():void{
      var urlRequest:URLRequest = new URLRequest("http://appldnld.apple.com/iTunes9/061-7656.20100616.ZTns2/iTunesSetup.exe");
      fileRef =
      new FileReference();
      fileRef.download(urlRequest,
      "iTunesSetup.exe");
      fileRef.addEventListener(ProgressEvent.PROGRESS, setDownloadProgress);
      fileRef.addEventListener(Event.COMPLETE, completeHandler);
      private function setDownloadProgress(event:ProgressEvent):void{
      pbProgress.setProgress(event.bytesLoaded, event.bytesTotal);
      pbProgress.label =
      "Downloading [" + Math.round(event.bytesLoaded / event.bytesTotal * 100).toString() + "%]";
      private function completeHandler(event:Event):void{
      fileRef =
      null;
      Alert.show(
      "Download Completed");
      </mx:Script>
      <mx:VBox
      top="10" left="10">
      <mx:Text buttonMode="true" click="downloadFile()" text="Download File" textDecoration="underline" fontSize="12"/>
      <mx:ProgressBar visible="{fileRef != null}" mode="manual" label="" id="pbProgress" labelPlacement="center"/>
      </mx:VBox>
      </mx:WindowedApplication>
        • 1. Re: download file without prompt window in flex?
          Matt Le Fevre Level 4
          Topic has come up many times, and nobody seems to have managed a work around, so i'm pretty confident saying it's impossible still.
          think about it, if you could do that, imagine the exploitation you could have if you could download stuff without the user knowing about it.
          • 2. Re: download file without prompt window in flex?
            Prashant@Mdocs Level 1
            thanks for ur reply,    actually i have AIR application, And AIR allows File System Access, so i think their must be way to do this by AIR.
            • 3. Re: download file without prompt window in flex?
              BhaskerChari Level 4
              Hi Prashanth,
              You can make use of the UrlLoader class instead of FileReference class to download the assets without prompt..As suggested it is almost impossible to eliminate the Prompt dialog box with FileReference class due to Security reasons...
              Check the below class for reference...
              package
              cfsc.includes
              import flash.display.LoaderInfo;
              public class DownloadAssets
              import flash.events.HTTPStatusEvent;
              import flash.events.IOErrorEvent;
              import flash.events.SecurityErrorEvent;
              import flash.net.URLLoaderDataFormat;
              import flash.system.Capabilities;
              import flash.events.Event;
              import flash.utils.ByteArray;
              import flash.net.URLLoader;
              import flash.net.URLRequest;
              import flash.display.Loader;
              import mx.rpc.xml.SimpleXMLDecoder;
              import cfsc.model.ModelLocator;
              import flash.filesystem.File;
              import flash.filesystem.FileStream;
              import flash.filesystem.*;
              Bindable]
              public var model : ModelLocator = ModelLocator.getInstance();
              private var request:URLRequest = new URLRequest();
              private var loader:URLLoader = new URLLoader;
              private var imgData:ByteArray;
              private var directory:File;
              private var currentImageName:String = "";
              private var currIndex:Number = 0;
              public function DownloadAssets()
              currIndex = 0;
              var myFile:File = File.applicationStorageDirectory.resolvePath("Data");
              if(myFile.exists)
              myFile.deleteDirectory(
              true);
              //deleteDirectoryContents();
              loader.dataFormat = URLLoaderDataFormat.BINARY;
              loader.addEventListener(Event.COMPLETE, onImgLoadComplete);
              loader.addEventListener(IOErrorEvent.IO_ERROR, ioErrorHandler);
              loader.addEventListener(HTTPStatusEvent.HTTP_STATUS, httpStatusHandler);
              loader.addEventListener(SecurityErrorEvent.SECURITY_ERROR, securityErrorHandler);
              downloadAndSaveAssets();
              public function downloadAndSaveAssets():void
              var imageName:String;
              var imageUrl:String;
              imageName = model.acAssetsInfo.getItemAt(currIndex).MediaFilePath;
              currentImageName = imageName;
              if(model.acAssetsInfo.getItemAt(currIndex).MediaType == 1 || model.acAssetsInfo.getItemAt(currIndex).TypeOfMedia == "Default")
              imageUrl = model.serverPath +
              "Data/DefaultMedia/" + imageName;
              else if(model.acAssetsInfo.getItemAt(currIndex).MediaType == 2 || model.acAssetsInfo.getItemAt(currIndex).TypeOfMedia == "Location")
              "Data/LocationMedia/" + imageName;
              else if(model.acAssetsInfo.getItemAt(currIndex).MediaType == 3 || model.acAssetsInfo.getItemAt(currIndex).TypeOfMedia == "Ad")
              request.url = imageUrl;
              request.useCache =
              false;
              request.manageCookies =
              false;
              request.cacheResponse =
              false;
              try
              loader.load(request);
              catch (err:Error)
              trace("Unable to load URL: " + err);
              trace("\rStatus: loading remote image ");
              private function onImgLoadComplete(event:Event):void
              imgData = event.target.data;
              trace("\rStatus: image loaded ");
              writeBytes();
              currIndex++;
              toDownload();
              private function securityErrorHandler(event:SecurityErrorEvent):void
              trace("securityErrorHandler: " + event);
              currIndex++;
              toDownload();
              private function httpStatusHandler(event:HTTPStatusEvent):void
              trace("httpStatusHandler: " + event);
              private function ioErrorHandler(event:IOErrorEvent):void
              trace("ioErrorHandler: " + event);
              currIndex++;
              toDownload();
              private function writeBytes():void
              trace("\rStatus: writing file locally ");
              var directory:File = File.applicationStorageDirectory.resolvePath("Data");
              if(!directory.exists)
              directory.createDirectory();
              directory = directory.resolvePath(currentImageName.toString());
              else
              var myFileStream:FileStream = new FileStream();
              myFileStream.open(directory, FileMode.WRITE);
              myFileStream.writeBytes(
              this.imgData, 0, this.imgData.length);
              myFileStream.close();
              /*private function toDownload():void
              if(model.acAssetsInfo.length > currIndex)
              downloadAndSaveAssets() ;
              else
              //getDirectoryContents(); // This conditions will be satisfied when all the media files are downloaded and starts the transition play timer(setAssetsTimer)
              if(currIndex == 5)
              getDirectoryContents() ; // Calling the transition play timer(setAssetsTimer) when the currIndex is 5 without waiting for all media files to be download
              else// This conditions will be satisfied when all the media files are downloaded and starts the transition play timer(setAssetsTimer)
              if(model.acAssetsInfo.length < 5)
              if(currIndex == 5)
              private function getDirectoryContents():void
              //if(currIndex >= model.acAssetsInfo.length)
              model.isSynchnozingWithServer =
              false;
              directory = File.applicationStorageDirectory.resolvePath(
              "Data");
              if(directory.exists)
              model.arrAssets = directory.getDirectoryListing();
              model.mainView.setAssetsTimer();
              private function deleteDirectoryContents():void
              for(var intLoop:int=0;intLoop<model.arrAssets.length;intLoop++)
              directory = directory.resolvePath(model.arrAssets[intLoop].nativePath);
              directory.addEventListener(Event.COMPLETE, completeHandler);
              directory.addEventListener(IOErrorEvent.IO_ERROR,ioErrorHandlerFun);
              //directory.deleteFileAsync();
              if(directory.nativePath != model.strFilePathInUse)
              //Alert.show(model.strFilePathInUse);
              directory.deleteFile();
              trace("Successfully deleted.");
              private function ioErrorHandlerFun(event:Event):void
              if(event.type == "ioError")
              trace(event.type.toString());
              Bhasker Chari
              • 4. Re: download file without prompt window in flex?
                thanks for ur reply,...............is there any demo simple code for downloadin
                g files from server  in air application using urlstream and filestream class?plz give me...thanks
                • 5. Re: download file without prompt window in flex?
                  Hi Prashanth,
                  Check out the below links these may be helpful:
                  http://stackoverflow.com/questions/342994/download-a-file-with-adobe-air
                  http://stackoverflow.com/questions/3061364/filestream-problem
                  http://www.actionscript.org/forums/showthread.php3?t=202599
                  If this post answers your question or helps, please kindly mark it as such.
                  Bhasker Chari
