2 Replies Latest reply on Jul 14, 2010 6:07 AM by BhaskerChari
    title bar
    flex_kkm
      how can i remove title bar of a air Application?...
        • 1. Re: title bar
          BhaskerChari Level 4
          Hi flex_kkm,
          You can make use of the showTitleBar="false" property of the root WindowApplication tag...
          You can also use other properties such as showTitleBar="false" showStatusBar="false" showGripper="false" showFlexChrome="false" to chnage the other properties of air window app..
          Bhasker Chari.S
          • 2. Re: title bar
            Solydest Level 2
            Which version of AIR are you using?
            In Flex 4.1 and AIR 2.0 if you set the <systemChrome> tag in the application descriptor file to <systemChrome>none</systemChrome> it removes it for you.
