2 Replies Latest reply on Jul 14, 2010 7:44 AM by richard.szalay
    Lambda expressions and compiler extensions
    richard.szalay
      Hi guys,
      I'm working on a project that is designed to play nicely with closures (anonymous functions) and it would be really nice if lambda expressions were supported due to the abbreviated syntax.
      I posted a question on these forums last year and the reply mentions a "custom asc extension". Is the compiler (even if it's just 4.0) extensable in a way that support for lambda expressions could be added? If it's not *that* extensible, how much effort would be involved?
      If it's simply not possible, can I make a language request for the next release?
      Cheers,
      Richard
      PS. FYI, here are the requirements for a lambda expressions as they would work in the AVM:
      "x:int => x + 1" is equivalent to "function (x:int) : int { return x+1; }"
      "(x:int) => methodThatReturnsVoid(x)" is equivalent to "function (x:int) : void { methodThatReturnsVoid(x); }"
      "() => 5" is equivalent to "function () : int { return 5; }"
      "_ => 5" is equivalent to "function (_ : Object) : int { return thereIsAnArgumentButIWontUseIt(); }"
          bracesMeansICanUseMultipleStatements();
          return butIHaveToUseReturn();
      is equivalent to
      "function():void
      ... etc
        • 1. Re: Lambda expressions and compiler extensions
          rtalton Level 4
          Doesn't Adobe have a feature request area somewhere for Actionscript? I know it's not here in their help forum.
          I'm using lambdas and anonymous types all the time (.NET/LINQ development) but am still very comfortable with Actionscript 3 as-is. It was never meant to compete feature-for-feature with the likes of C#. Otherwise, I would probably know where the feature request area is located and would be filing enhancement and feature requests every day.
          • 2. Re: Lambda expressions and compiler extensions
            richard.szalay Level 1
            I think you misunderstood my post. I was asking for a pointer in the right direction to implement the support myself, and how the extension would integrate into an existing sdk installation.
            I realise that AS3 is not intended to match C# feature-for-feature, but I've been working on a port of Rx and lambda-syntax for anonymous functions would be much more pleasing on the eye.
            Besides, if I were set on requesting a feature, it'd be proper generics support!
