1 Reply Latest reply on Aug 9, 2010 9:47 PM by Balakrishnan V
    addsimpleHeader
    alrossers
      Fellow devs,
      I'm trying to call a web service by passing a SOAP parameter/header to the method, using the following code:
      import mx.rpc.soap.*;
      import mx.core.*;
      import mx.rpc.events.*;
      import fl.data.DataProvider;
      import com.adobe.crypto.WSSEUsernameToken;
      var myWebService = new WebService();
      myWebService.addSimpleHeader
      ("header3", "http://www.w3.org/2001/XMLSchema", "symbol","MSFT");
      myWebService.addEventListener("load", loadDone);
      //myWebService.loadWSDL("http://www.webservicex.net/country.asmx?WSDL");
      myWebService.loadWSDL("http://www.webservicex.net/stockquote.asmx?wsdl");
      var myOperation:Operation;
      function loadDone(evt:LoadEvent)
      myOperation = Operation(myWebService.getOperation("GetQuote"));
      myOperation.addEventListener("fault", wsError);
      myOperation.addEventListener("result", wsResult);
      myOperation.send();
      function wsError(evt:FaultEvent)
      function wsResult(evt:ResultEvent)
      var xml:XML = XML(evt.result);
      Test.text = xml.toString();
      If I just run that code without dealing with parameter/header (see commented out line), it runs fine.  But when I try to pass in a parameter via addsimpleheader, it always returns "exception".  The web service country.asmx returns all countries; it doesn't need any parameters.  That's the one that works fine, without the addsimpleHeader.  But stockquote.asmx requires you to pass in a parameter, which is why I'm trying to get addsimpleHeader to work.
      Any suggestions?
      Alan
