6 Replies Latest reply on Oct 1, 2010 5:12 AM by ven`
    Garbage collection
    SamuelJonasson
      I can't get OSMF object garbage collected.  I read somewhere that I should set the media property to null and then the media would unload.  I guess unloading the media itsn't enough.  What more do I have to do to get the OSMF objects garbage collected?
      This is what I am currently trying - but not working:
      _mediaPlayerSprite.mediaPlayer.stop();
      _mediaPlayerSprite.resource = null;
      _mediaPlayerSprite.media = null;
      _mediaPlayerSprite.parent.removeChild(_mediaPlayerSprite);
      _mediaPlayerSprite = null;
      Best,
      Sammi
        • 1. Re: Garbage collection
          SamuelJonasson Level 1
          Hmmm...
          I was hoping that there was an easy solution to this problem.  I am using a workaround now be "reusing" the player instead of removing it and reinstanciate.  But it doesn't feel good.
          How have you been making sure the player gets collected?
          Best,
          Sammi
          • 2. Re: Garbage collection
            weizhangstrobe Level 2
            Personally, I have not encountered a situation where I need to GC the player.
            -Wei Zhang
            Senior Computer Scientist
            Adobe Systems
            weizhang@adobe.com
            • 3. Re: Garbage collection
              Lenny1979
              Well... that's not that helpful, weizhangstrobe
              I do have a situation where I need to dispose the player: It is a large modular application, where a module is potentially loaded several times. And as we have a bunch of modules it is NOT a solution to keep all the stuff (several times) in the memory.
              Actually I am wondering why one has to explain this for literally every single Flash-component again anyway
              This being said: How do I unload a MediaPlayer, MediaElements (including Plugins), what do I do with the MediaFactory, etc etc? Are Streams/Downloads stopped?
              Thanks a lot,
              Lenny
              • 4. Re: Garbage collection
                bringrags Level 4
                You need:
                mediaPlayer.media = null;
                mediaContainer.removeMediaElement(mediaElement);
                I think that's basically it.  Note that we had an open bug related to memory leaks which might affect you (it's been fixed in trunk):
                https://bugs.adobe.com/jira/browse/FM-949
                If you're still seeing leaks after following the advice in the bug notes, then please add some details to the bug so we can quash this.
                • 5. Re: Garbage collection
                  Lenny1979 Level 1
                  thanks for the quick reply! I will try what you suggested, and I checked out the latest revision (#17552)
                  I replied to the bug-report as well
                  Best regards & thanks again,
                  Lenny
                  • 6. Re: Garbage collection
                    ven`
                    How do I figure out what the mediaElement is when the osmf is set up like this:
                    function create():void {
                         _osmf = new MediaPlayerSprite();
                         _osmf.mediaPlayer.autoPlay = true;
                         addChild(_osmf);
                         _osmf.resource = new URLResource(_url);
                    function destroy():void {
                         _osmf.mediaPlayer.stop();
                         _osmf.mediaPlayer.media = null;
                         _osmf.mediaContainer.removeMediaElement( ???? );
                         _osmf.resource = null;
                         _osmf.media = null;
                         removeChild(
                    _osmf);
                    _osmf = null;
                    EDIT:
                    Doh, ofcourse, it is the _osmf.media - making it look like this:
                         _osmf.mediaContainer.removeMediaElement(_osmf.media);
                         _osmf.media = null;
                         removeChild(
                    _osmf);
                    _osmf = null;
