I have several Library Projects with FlexUnit tests within them. They were running fine.
I am now getting "java.lang.reflect.InvocationTargetException" errors all the time. I've attached that, although I was getting some missing resource bundle errors as well. I think I've resolved that latter issues.
And FYI I'm on Mac (10.6.4) running Flash Builder plug-in (4.0, not ready to plunge into 4.0.1, yet, unless it helps with this particular issue) with Eclipse 3.5.2 M20100211-1343. I'm running Subclipse 1.6.10, HgEclipse 1.5.0.201001202311, AnyEditTools 2.3.200910041235, as well as a few other plug-ins.
Any help is greatly appreciated.
TIA,
Kirk
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:477)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java:944)
at com.adobe.flexbuilder.flexunit.debug.dialog.ConfigurationWizard.performFinish(ApplicationCreationAndConfigurationDialog.java:421)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:752)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1598)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1622)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1607)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1396)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3484)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3068)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at com.adobe.flexbuilder.flexunit.debug.contextMenu.FlexUnitUtil.launchApplicationRunDialog(FlexUnitUtil.java:420)
at com.adobe.flexbuilder.flexunit.debug.dialog.FlexUnitLaunchShortcut.launchInternal(FlexUnitLaunchShortcut.java:92)
at com.adobe.flexbuilder.flexunit.debug.dialog.FlexUnitLaunchShortcut.launch(FlexUnitLaunchShortcut.java:65)
at org.eclipse.debug.internal.ui.launchConfigurations.LaunchShortcutExtension.launch(LaunchShortcutExtension.java:434)
at org.eclipse.debug.internal.ui.actions.LaunchShortcutAction.run(LaunchShortcutAction.java:73)
at org.eclipse.debug.internal.ui.actions.LaunchShortcutAction.runWithEvent(LaunchShortcutAction.java:121)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.jface.action.ActionContributionItem$9.handleEvent(ActionContributionItem.java:1284)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Caused by: java.lang.ClassCastException: com.adobe.flexbuilder.mxmlmodel.inlinestates.internal.SUnknownTag cannot be cast to com.adobe.flexbuilder.mxmlmodel.IInstance
at com.adobe.flexbuilder.mxmlmodel.AbstractArrayAccessor.newInstance(AbstractArrayAccessor.java:120)
at com.adobe.flexbuilder.mxmlmodel.inlinestates.internal.SContentHolder.newInstance(SContentHolder.java:58)
at com.adobe.flexbuilder.mxmlmodel.AbstractMXMLItem.newInstance(AbstractMXMLItem.java:221)
at com.adobe.flexbuilder.flexunit.ApplicationCreationUtil.insertComponent(ApplicationCreationUtil.java:1006)
at com.adobe.flexbuilder.flexunit.ApplicationCreationUtil.modifyApplicationTagAndInsertTestRunnerComponent(ApplicationCreationUtil.java:384)
at com.adobe.flexbuilder.flexunit.ApplicationCreationUtil.insertMXMLContent(ApplicationCreationUtil.java:330)
at com.adobe.flexbuilder.flexunit.ApplicationCreationUtil.createMXMLFlexUnitApplication(ApplicationCreationUtil.java:304)
at com.adobe.flexbuilder.flexunit.ApplicationCreationUtil.createFlexUnitApplication(ApplicationCreationUtil.java:129)
at com.adobe.flexbuilder.flexunit.debug.dialog.ConfigurationWizard.createAndLaunchApplicationFile(ApplicationCreationAndConfigurationDialog.java:479)
at com.adobe.flexbuilder.flexunit.debug.dialog.ConfigurationWizard.access$1(ApplicationCreationAndConfigurationDialog.java:471)
at com.adobe.flexbuilder.flexunit.debug.dialog.ConfigurationWizard$1.run(ApplicationCreationAndConfigurationDialog.java:413)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
... 58 more
Root exception:
Well I am not good in Java and it's a Java error. One of Java expert will help you surely.
