1 Reply Latest reply on Jul 16, 2010 10:53 AM by nmkFlex4u
    How to access Summary data calculated in an Advanced Data Grid in another component ?
    nmkFlex4u Level 1
      Hi
      I am new to Flex and am currently working on a test project to populate an Array (dp) using data bindings. However, I have two requi
      rements.
      1. I need to create a column whose values are populated based on two columns in the dataprovider-- ArrayCollection. In this case, th
      e values in column datafield="calValue" are calculated at run-time using an inline Item renderer.
      2. I need to calculate the Average value of ALL the values populated in the custom column datafield="calValue".
      There are a couple of problems I am facing in this regard. Firstly, though I am able to create the custom column using an Item rende
      rer, I am not able to obtain the Average value of the column using the GROUPING COLLECTION2, GROUPING FIELD, SUMMARY ROW classes. Se
      condly, How do I access the summary value created in the initDG() function. I want to be able to pass the summary value calculated a
      nd displayed in the Advanced Data Grid to the property of another component.
      Example:
      <s:Label id="LabelSummary" />
      private function setLabelText():viod
      LabelSummary.text = <SUMMARYVALUE>;
      I need to be able to display the summary value in the Label component. Also, I have noticed that the summary row is a collection of
      Array objects. (I think--from my understanding !! not too sure though) I need the final summary value calculated in the initDG() fun
      ction to be accessible as an INTEGER or NUMBER. When I try typecasting and displaying the Label.Text property, I get the value:
      [object Summary Row] displayed in the Label. Hope I have given a good overview of the problem I am facing.
      Hope this provides a greater insight.
      My .mxml files are:
      SummaryWithActionScriptADG.mxml
         xmlns:mx="library://ns.adobe.com/flex/mx" >
      <s:layout>
      <s:VerticalLayout paddingTop="10"
        horizontalAlign="center"/>
      </s:layout>
          <fx:Script>
              <![CDATA[
      import mx.collections.ArrayCollection;
      import mx.collections.Grouping;
      import mx.collections.GroupingCollection2;
      import mx.collections.GroupingField;
      import mx.collections.SummaryField2;
      import mx.collections.SummaryRow;
      private var arrayData:Array=[
      {name:"banana",cat:"bakery",cost:.99,qty:2,amount:4},
      {name:"bread",cat:"bakery",cost:1.99,qty:3,amount:5},
      {name:"cheddar cheese",cat:"bakery",cost:4.52,qty:6,amount:4},
      {name:"sour cream",cat:"bakery",cost:.33,qty:2,amount:6},
      {name:"orange",cat:"bakery",cost:.52,qty:4,amount:7},
      {name:"donut",cat:"bakery",cost:.33,qty:2,amount:8},
      {name:"yogurt",cat:"bakery",cost:.99,qty:5,amount:9},
      {name:"milk",cat:"bakery",cost:2.99,qty:2,amount:10},
      {name:"apple",cat:"bakery",cost:1.05,qty:4,amount:8},
      {name:"colby cheese",cat:"bakery",cost:3.05,qty:4,amount:9}];
                  [Bindable]
                  private var dp:ArrayCollection=new ArrayCollection(arrayData);
      private function initDG():void
      var myGroupColl:GroupingCollection2=new GroupingCollection2();
      myGroupColl.source=myADG.dataProvider;
      var group:Grouping=new Grouping();
      var gf:GroupingField=new GroupingField("cat");
      group.fields=[gf];
      myGroupColl.grouping=group;
      var sr:SummaryRow=new SummaryRow();
      var sf:SummaryField2=new SummaryField2();
      sf.dataField="qty";
      sf.summaryOperation="SUM";
      sf.label="summary";
      sr.fields=[sf];
      sr.summaryPlacement="group";
      gf.summaries=[sr];
      labelDisplay.text = gf.summaries.toString();
      myGroupColl.refresh();
      myADG.dataProvider=myGroupColl;
      var summaryVar:Array=new Array([sr]);
      var summaryVarInt:uint=uint(summaryVar[0]);
      labelDisplay.text=gf.summaries.pop();
      private function summaryCal():void
      group.fields=[gf];
      sf.dataField="qty";
      sf.label="summary";
      sr.fields=[sf];
      gf.summaries=[sr];
      labelDisplay.text=summaryVar.length.toString();
      private function testDG():void
          </fx:Script>
      <s:Label id="labelDisplay" text="Hello"/>
      <mx:AdvancedDataGrid id="myADG"
          dataProvider="{dp}"
      creationComplete="initDG()">
          <mx:columns>
              <mx:AdvancedDataGridColumn dataField="name"/>
              <mx:AdvancedDataGridColumn dataField="cost"/>
              <mx:AdvancedDataGridColumn dataField="qty"/>
      <mx:AdvancedDataGridColumn dataField="amount"/>
      <mx:AdvancedDataGridColumn  id="calCol" headerText="CalculatedValue" dataField="calValue">
      <mx:itemRenderer>
      <fx:Component>
      <mx:Text text="{uint(data.qty)/(uint(data.amount)+uint(data.qty))}"/>
      </fx:Component>
      </mx:itemRenderer>
      </mx:AdvancedDataGridColumn>
          </mx:columns>
      <mx:rendererProviders>
          <mx:AdvancedDataGridRendererProvider
              dataField="summary"
              columnIndex="1"
              columnSpan="2"
              renderer="renderers.SummaryTextForAS"/>
      </mx:rendererProviders>
      </mx:AdvancedDataGrid>
      </s:Application>
      SummaryTextforAS.mxml
      <s:MXAdvancedDataGridItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
        focusEnabled="true">
      <s:Label id="lblData" top="0" left="0" right="0" bottom="0" text="Total number of items: {data.summary}" />
      </s:MXAdvancedDataGridItemRenderer>
      Thanks in advance.
      Regards
      -Krishna
