I use RoboHelp HTML 7.0.3.001 and generate Microsoft HTML Help as the output file of my project. Each time I open generated CHM file, the only default topic is displayed. Then I should click Show button on the toolbar to view the Contents tab containing folders and other topics...
It seems to me, in the previous versions of the RoboHelp (may be in x5 version), there was a check box in Project Settings that allowed me to open TOC panel when the help was opened.
Could this be configured somewhere in RoboHelp 7.0.3.001? I can't find an appropriate option and hope for your help
Thanks in advance,
Olga
Hi there
Indeed you may control this. You do it via the Window Properties. So click View > Pods > Project Set-up. Then expand the Windows folder and double-click the CHM window to see the Windows Properties.
You should be interested in the Tri-pane Options area. Ensure that the option Hide Nav Pane on Startup isn't enabled.
If you find it's not enabled, try enabling it and dismissing the dialog to re-write the values. Then open the dialog again and clear the option.
If this fails, you may simply nee
...Copy link to clipboard
Hi there
If this fails, you may simply need to create a new window and assign it in the Single Source Layout recipe.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now! |
Thanks a lot! It works
