4 Replies Latest reply on Sep 3, 2010 10:16 AM by chris.campbell
    AIR 2 fullscreen_interactive with stageScale
    Rack@DJ
      I did Adobe AIR application while ago in AIR 1.5 for my client..
      Application was in fullscreen mode with interactive abilities:
      stage.scaleMode = StageScaleMode.SHOW_ALL;
      stage.align = StageAlign.TOP_LEFT;
      stage.displayState = StageDisplayState.FULL_SCREEN_INTERACTIVE;
      Everything worked perfectly when I had AIR 1.5 installed on my PC...
      After I update AIR to version 2, fullscreen is not fuctional anymore as it should be because stage doesn't scale to SHOW_ALL property..it looks like that application has "StageScaleMode.NO_SCALE" applied to it and application doesn't scale up to my screen..
      Is there some changes in AIR 2 how is dealing with this properties??
      Is there any way how to avoid that problem??
      Thanks for help
        • 1. Re: AIR 2 fullscreen_interactive with stageScale
          RoryMacDonald
          Im running into this same problem. Can somebody at Adobe respond?
          It's a real pain that this has suddenly changed in a released piece of software and is causing me a massive headache with my client!
          Rory
          • 2. Re: AIR 2 fullscreen_interactive with stageScale
            thilgen
            Rory and Rack
            I am not sure we have any issues logged about this internally.
            Could you provide a small sample that demonstrates the issue so we can take a look?
            Chris Thilgen
            AIR Engineering
            • 3. Re: AIR 2 fullscreen_interactive with stageScale
              Rack@DJ Level 1
              Rory:
              I still havn't solved this problem, but I manage to force AIR go fullscreen..
              Use scaleX and scaleY property for root to fit your application:
              private var factX:Number;
              private var factY:Number;
              private var factScale:Number;
              public function MyDocumentClass()
                   this.stage.scaleMode = StageScaleMode.SHOW_ALL;
                   this.stage.align = StageAlign.TOP_LEFT;
                   //size of flash movie is 1280 x 800
                   factX = Capabilities.screenResolutionX/1280;
                   factY = Capabilities.screenResolutionY/800;
                   factScale = this.scaleX = this.scaleY = (factX<factY) ? factX:factY;
                   this.stage.displayState = StageDisplayState.FULL_SCREEN_INTERACTIVE;
                   //this mess up my comboboxe dropdown width so I had to use this:
                   myCombo.dropdownWidth = myCombo.width * factScale;
              I hope this will help you..
              I will also create sample application for thilgen, but at the moment I don't have time..
              Best regards..
              • 4. Re: AIR 2 fullscreen_interactive with stageScale
                chris.campbell Adobe Employee
                Moved thread to the Adobe AIR Development forum
