0 Replies Latest reply on Jul 15, 2010 7:39 AM by tomj
    [svn:fx-trunk] 16929: Add a [Mixin] class that will register the required class aliases in the event the mxml compiler generation   [RemoteClass(alias="")] code is not called because an application does not use the Flex UI framework .
    tomj Adobe Employee
      Revision: 16929
      Revision: 16929
      Author:   tjordahl@adobe.com
      Date:     2010-07-15 07:38:44 -0700 (Thu, 15 Jul 2010)
      Log Message:
      Add a class that will register the required class aliases in the event the mxml compiler generation  [RemoteClass(alias="")] code is not called because an application does not use the Flex UI framework.
      Add a reference to this class in the RPCClasses file so it always gets loaded.
      QE notes: Need a remoting and messaging regression test that doesn't use Flex UI.
      Bugs: Watson bug 2638788
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/rpc/src/RPCClasses.as
      Added Paths:
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/utils/RpcClassAliasInitializer.as
