11 Replies Latest reply on Jul 16, 2010 4:41 AM by sstanleyau
    Applescript for folder reading
    sudar1983_14 Level 2
      I need a applescript for the below script.
      var inputDirectory="D:\\IndFiles";
      var inddFiles=new Array();
      inddFiles=Folder(inputDirectory).getFiles();
      //Suppress all dialogs
      app.scriptPreferences.userInteractionLevel = UserInteractionLevels.neverInteract;
      for(var indCount=0; indCount < inddFiles.length; indCount++)
          if (String(inddFiles[indCount]).match(/\.indd$/i))
              var aDoc=app.open(File(inddFiles[indCount]), true);
              //Save and close
              aDoc.close(2036691744);
      Arivu.
        • 1. Re: Applescript for folder reading
          sstanleyau Level 4
          I'd use something like this:
          set theFolder to (choose folder) as text
          set fileList to paragraphs of (do shell script "ls " & quoted form of POSIX path of theFolder & " | egrep '*.indd' | tr ':' '/'")
          tell application "Adobe InDesign CS5"
          set user interaction level of script preferences to never interact
          repeat with i from 1 to count of fileList
          open alias (theFolder & item i of fileList)
          -- do stuff
          close document 1 saving yes
          end repeat
          end tell
          • 2. Re: Applescript for folder reading
            Translate is not working here.
            Still i am getting colon in the path.
            Arivu
            • 3. Re: Applescript for folder reading
              Muppet Mark-QAl63s Level 4
              I would have done something like this…
              tell application "Finder"
              set fileList to (every file of theFolder whose name extension is "indd") as alias list
              end tell
              tell application "Adobe InDesign CS2"
              if fileList {} then
              open (item i of fileList)
              -- do stuff
              end repeat
              else
              display alert "No 'InDesign' files to open?" giving up after 2
              end if
              end tell
              • 4. Re: Applescript for folder reading
                Im getting the below error.
                     Can't make every file of alias "MyPath" whose name extension="indd" into type <<class alst>>
                Please assist me.
                Arivu.
                • 5. Re: Applescript for folder reading
                  sstanleyau Level 4
                  You want colons in the path. The tr is to change colons in names.
                  • 6. Re: Applescript for folder reading
                    sstanleyau Level 4
                    Yes, you can ask the Finder. The problem is that it's generally very slow (and getting slower), and depending on which version of the OS you're using, there are quirks to using alias list. Apple's advice is to use System Events instead, but that opens another whole can of worms. ls is efficient and robust.
                    • 7. Re: Applescript for folder reading
                      Again one favour for me.
                      Can you give me a script for reading the txt file (Path information stored here), Open each file and execute the process.
                      Arivu..
                      • 8. Re: Applescript for folder reading
                        sstanleyau Level 4
                        Are they HFS paths (using colons) or POSIX paths (using slashes)?
                        • 9. Re: Applescript for folder reading
                          POSIX paths (using slashes).
                          • 10. Re: Applescript for folder reading
                            With AppleScript you can use either POSIX or HFS paths. You just need to specify which you are passing. Shell will use POSIX, AppleScript by default likes HFS if you are going to coerce to an alias specifier (which is what most apps expect when using AppleScript). Here is another example that uses spotlight to find your files.
                            set theFolder to quoted form of POSIX path of (choose folder)
                            set fileList to paragraphs of (do shell script "mdfind -onlyin " & theFolder & " kMDItemDisplayName == '*.indd'")
                            open (POSIX file (item i of fileList) as alias)
                            -- do stuff
                            end repeat
                            end tell
                            I like 'mdfind' for its full POSIX paths and speed but it is recursive…
                            If you have problems with 'your code' then you would do better to post it. And also what OS version  you are using?
                            • 11. Re: Applescript for folder reading
                              sstanleyau Level 4
                              In that case it would be something like:
                              set theTextFile to choose file
                              set fileList to paragraphs of (read theTextFile)
                              try -- to allow for blank paragraphs at end
                              -- do stuff
                              end try
                              end repeat
                              end tell
