1 Reply Latest reply on Jul 15, 2010 10:49 AM by pguerett
    List Box Display question
    MarieS2
      I am using LiveCycle ES 8.2 and have created a new form from a blank page.  I created a list box and enabled it to be multi-select.  When I go into the populated form, I cannot scroll through the list to see the selections and when I print, I can't see the items selected.
      I went into the Commit On box and as someone else stated I only have the Exit button, not the Select button.  Can someone assist?
        • 1. Re: List Box Display question
          pguerett Level 6
          When you put focus on the listbox scroll bars will appear to allow you to scroll up/down. The commit on select is only available on the DDList (a common dialog is used for the DDLists and Listboxes). If you exit the list then hit print you will see your selections highlighted.
          Paul
