8 Replies Latest reply on Jul 19, 2016 8:49 AM by JJMack
    Script to search layer names
    jmug45
      Hi -
      Does anyone know if there is a script that can search through layer names within a file for a specific text string and then select it as the active layer?
      For instance, if a file has 4 layers, named My LayerX, LayerY, LayerZ, LayerA, I want to automatically search for a layer that has the text "rA" and make it the active layer.
      Thanks.
        • 2. Re: Script to search layer names
          Michael L Hale Level 5
          This requires CS4 or better. It searchs using a RegExp and Action Manager so it should be very fast. It is set up now to deal with more than one matching layer.
          var re = /rA/;// a reg exp
          var matches = collectNamesAM(re);// get array of matching layer indexes
          for( var l = 0; l < matches.length; l++ ){
              makeActiveByIndex( l, false );
              // do something with layer
              alert(app.activeDocument.activeLayer.name);
          }// next match if any
          function collectNamesAM(re){
               var allLayers = new Array();
             var startLoop = Number( !hasBackground() );
             var endLoop = getNumberOfLayer();
             for( var l = startLoop;l < endLoop; l++){
                  while( !isValidActiveLayer( l ) ) {
                      l++;
                  if( getLayerNameByIndex( l ).match(re) != null){
                      allLayers.push( l );
               return allLayers;
          // Function: getActiveLayerIndex
          // Description: Gets gets the Action Manager API index
          //                        of activeLayer corrected for Background Layer
          // Usage: var idx = getActiveLayerIndex();
          // Input: None
          // Return: Number - correct AM itemIndex
          // Dependices: hasBackground
          function getActiveLayerIndex() {
               var ref = new ActionReference();
               ref.putProperty( 1349677170 , 1232366921 );
               ref.putEnumerated( 1283027488, 1332896878, 1416783732 );
               var res = executeActionGet(ref).getInteger( 1232366921 )
        - Number( hasBackground() );
               res == 4 ? res++:res// why the skip in this doc?
               return res;
          // Function: isValidActiveLayer( )
          // Description: Checks LayerSection for 'real' layers
          // Usage: if( isValidActiveLayer() )
          // Input: None
          // Return: Boolean - True if not the end of a Set
          // Notes:  Needed only if the layer was made active
          //               using Action Manager API
          function isValidActiveLayer( idx ) {
               var propName = stringIDToTypeID( 'layerSection' );// can't replace
               ref.putProperty( 1349677170 , propName);// TypeID for "Prpr"
               // 'Lyr ", idx
               ref.putIndex( 1283027488, idx );
               var desc =  executeActionGet( ref );
               var type = desc.getEnumerationValue( propName );
               var res = typeIDToStringID( type );
               return res == 'layerSectionEnd' ? false:true;
          // Function: hasBackground
          // Description: Test for background layer using AM API
          // Usage: if( hasBackground() );
          // Input: None
          // Return: Boolean - true if doc has background layer
          // Notes:  Requires the document to be active
          //  DOM:  App.Document.backgroundLayer
          function hasBackground(){
              var res = undefined;
              try{
                  ref.putProperty( 1349677170 , 1315774496);
                  ref.putIndex( 1283027488, 0 );
                  executeActionGet(ref).getString(1315774496 );;
                  res = true;
              }catch(e){ res = false}
              return res;
          function makeActiveByIndex( idx, forceVisible ){
               try{
                    var desc = new ActionDescriptor();
                    ref.putIndex(charIDToTypeID( "Lyr " ), idx)
                    desc.putReference( charIDToTypeID( "null" ), ref );
                    desc.putBoolean( charIDToTypeID( "MkVs" ), forceVisible );
                    executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
               }catch(e){ return -1;}
          function getNumberOfLayer(){
          ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var desc = executeActionGet(ref);
          var numberOfLayer = desc.getInteger(charIDToTypeID("NmbL"));
          return numberOfLayer;
          function getLayerNameByIndex( idx ) {
              ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "Nm  " ));
              ref.putIndex( charIDToTypeID( "Lyr " ), idx );
              return executeActionGet(ref).getString(charIDToTypeID( "Nm  " ));;
          • 3. Re: Re: Script to search layer names
            barra
            @Michael: Thank you for the awesome code!
            Annotation: line 4 must be the following:
                makeActiveByIndex( matches[l], false );
            • 4. Re: Script to search layer names
              vigneshr15256207
              hi There is any same kind of scripts available for Adobe illustrator
              • 5. Re: Script to search layer names
                I do not use AI one complex Adobe prouduct Photoshop is all I can handle.
                • 6. Re: Script to search layer names
                  StrongBeaver Level 3
                  Micheal what do you mean it requires Action Manager, I tried to execute after doing the change barra put forward and nothing happened ?
                  • 7. Re: Script to search layer names
                    Chuck Uebele Adobe Community Professional & MVP
                    Michael has passed away. Action Manger code is code generated by Scriptlistener - for the most part as opposed to DOM code.
                    • 8. Re: Script to search layer names
                      The functions in Michael script were made from Action Manager Coder recorded by the Scriptlistener Plug-in in some of the functions variable were added to replace hard coded values recorded by the Scriptlistener plug-in the variable are the functions parameters. I have highlighted the variable and the statment's that  uses Photoshop Action manager
                      1. function getActiveLayerIndex() {
                      2.      var ref = new ActionReference();
                      3.      ref.putProperty( 1349677170 , 1232366921 );
                      4.      ref.putEnumerated( 1283027488, 1332896878, 1416783732 );
                      5.      var res = executeActionGet(ref).getInteger( 1232366921 )
                      6.                                                        - Number( hasBackground() );
                      7.      res == 4 ? res++:res// why the skip in this doc?
                      8.      return res;
                      9. /*//////////////////////////////////////////////////////////////////////////////
                      10. // Function: isValidActiveLayer( )
                      11. // Description: Checks LayerSection for 'real' layers
                      12. // Usage: if( isValidActiveLayer() )
                      13. // Input: None
                      14. // Return: Boolean - True if not the end of a Set
                      15. // Notes:  Needed only if the layer was made active
                      16. //               using Action Manager API
                      17. //////////////////////////////////////////////////////////////////////////////*/
                      18. function isValidActiveLayer( idx ) {
                      19.      var propName = stringIDToTypeID( 'layerSection' );// can't replace
                      20.      var ref = new ActionReference();
                      21.      ref.putProperty( 1349677170 , propName);// TypeID for "Prpr"
                      22.      // 'Lyr ", idx
                      23.      ref.putIndex( 1283027488, idx );
                      24.      var desc =  executeActionGet( ref );
                      25.      var type = desc.getEnumerationValue( propName );
                      26.      var res = typeIDToStringID( type );
                      27.      return res == 'layerSectionEnd' ? false:true;
                      28. };
                      29. /*//////////////////////////////////////////////////////////////////////////////
                      30. // Function: hasBackground
                      31. // Description: Test for background layer using AM API
                      32. // Usage: if( hasBackground() );
                      33. // Input: None
                      34. // Return: Boolean - true if doc has background layer
                      35. // Notes:  Requires the document to be active
                      36. //  DOM:  App.Document.backgroundLayer
                      37. //////////////////////////////////////////////////////////////////////////////*/
                      38. function hasBackground(){
                      39.     var res = undefined;
                      40.     try{
                      41.         var ref = new ActionReference();
                      42.         ref.putProperty( 1349677170 , 1315774496);
                      43.         ref.putIndex( 1283027488, 0 );
                      44.         executeActionGet(ref).getString(1315774496 );;
                      45.         res = true;
                      46.     }catch(e){ res = false}
                      47.     return res;
                      48. };
                      49. function makeActiveByIndex( idx, forceVisible ){
                      50.      try{
                      51.           var desc = new ActionDescriptor();
                      52.           var ref = new ActionReference();
                      53.           ref.putIndex(charIDToTypeID( "Lyr " ), idx
                      54.           desc.putReference( charIDToTypeID( "null" ), ref );
                      55.           desc.putBoolean( charIDToTypeID( "MkVs" ), forceVisible );
                      56.           executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
                      57.      }catch(e){ return -1;}
                      58. };
                      59. function getNumberOfLayer(){
                      60. var ref = new ActionReference();
                      61. ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                      62. var desc = executeActionGet(ref);
                      63. var numberOfLayer = desc.getInteger(charIDToTypeID("NmbL"));
                      64. return numberOfLayer;
                      65. };
                      66. function getLayerNameByIndex( idx ) {
                      67.     var ref = new ActionReference();
                      68.     ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "Nm  " ));
                      69.     ref.putIndex( charIDToTypeID( "Lyr " ), idx );
                      70.     return executeActionGet(ref).getString(charIDToTypeID( "Nm  " ));;
                      71. };
