3 Replies Latest reply on Jul 16, 2010 4:20 AM by martcol
    saved .psd as .ai and artboards won't behave....
    martcol Level 4
      Sorry if this is basic question but I don't really know where to start looking to see if this is a straight forward behaviour or not.  I'm in CS4.
      I opened up a .psd file and saved it as .ai file from within Illustrator.
      First though: I notice that the color panel doesn't have any colors in it.  You know, when you click one of these icons to change fill or stroke color:
      Then I wanted to place a smaller artboard in the inside of the default artboard (the original document boundary) so that I could save a web graphic that's a part of the image but I can get to place a new artboard in the artboard view but save for web just wants to print the default artboard.
      Hope that's clear.
      Martin
        • 1. Re: saved .psd as .ai and artboards won't behave....
          martcol Level 4
          Numpty Alert!
          Checked Clip to Artboard.  Things going a little smoother now!
          Still perplexed about the swatch think though?
          Martin
          • 2. Re: saved .psd as .ai and artboards won't behave....
            sanjaysingh82 Level 1
            To draw Artboard inside artboard:
            if you want to draw an Artboard Inside Artboard using artboard tool follow the follwing steps:
            select artboard tool to go in artboard tool mode-> mouse over the area on which you want to draw the artboard -> press shift and start drawing artboard and once you have started drawing artboard release shift and continue drawing artboard.
            • 3. Re: saved .psd as .ai and artboards won't behave....
              martcol Level 4
              Thank you for chipping in Sanjaysingh84.
              I think my problem arose because I had unchecked clip to artboard.  I could not work out why save for web kept defaulting to the document boundaries.  I kept activating the artboard I wanted and it wouldn't work.  I thought that it had happened because I saved a .psd file and something strange was going on.  I haven't done that much as I usually start from a new document in Illy.
              Any idea about the color selecting thing?  I've noticed before that some documents don't seem to have any swatches available in that flyout box and I don't know how to fill it with colors.
              Many thanks
              Martin
