3 Replies Latest reply on Jul 16, 2010 12:06 AM by Jim_Simon
    Setting Default File Location
    Andrew Glennie
      Hi All,
      Just installed Premiere Pro CS5 and have found difficulty in locating where to set the global location for the scratch disks. The only place I have located so far is in the project file. If this is only place, to have to set the scratch disk each time is rather onerous. Hopefully someone can point me to the (hidden) location for setting this globally.
      Regards
      Andrew
        • 1. Re: Setting Default File Location
          Jim_Simon Level 8
          This is actually a very welcome Project setting, so now we don't have to change the Scratch Disk settings every time we open a different project.  (I've always got about half a dozen going at any given time, and changing the global Scratch settings every time I opened one was a major hassle.  This new way is MUCH better.)
          • 2. Re: Setting Default File Location
            Andrew Glennie Level 1
            Thanks - think our situations are a bit different. I have multiple users on the single system so reminding each to set the scratch drive each time they create a project will be a mission.
            We used to have Premiere Elements which had a single scratch location, within which each project had its own subfolder. Hence my expectation that Pro would operate in the same way.
            Perhaps Adobe could provide us with the option of working both ways - a global setting which can be overridden within the project.
            Andrew
            • 3. Re: Setting Default File Location
              Jim_Simon Level 8
              Create an empty project with the Scratch settings you want, and have each user always start with that (doing a Save As... before any actual work is done.)
