4 Replies Latest reply on Jul 19, 2010 12:05 AM by danilopau
    Axes problem on chart scrolling
    danilopau
      first of all sorry for my English!
      Well, i'm developing the scrolling of a chart: i mean, if i drag a chart, i can move around it while the axes just remain where they are: this is to navigate the chart when the start/end values are greater than the axes limits (both X y Y axes).
      The technique is simple: i just calculate the "delta" of the mouse when draggin (converting the x/y mouse coordinate in a chart value x/y coordinate) and changing the min/max values of the axes.
      The problem is with the movement on the vertical axis.. when i move the graph, i don't have a fixed label at the top of the vertical axis, but the labels move as i move the graph.. in this way, i don't always have a label at the very top of the vertical axis, and the desappearing/appearing of the labels make the graph "dancing".. is like the appearing of the next label for the axis make the axis/chart length change for a moment, or make the movement larger than really is.. this doesn't happen with the horizontal axis, even if the labels move and i don't have a label at the very end/beginning of the axis..
      It is a little hard to explain, i hope i've been clear..
      I don't know hot to fix it.. i was wondering if there is a way to put a value label at the very top/end of an axis no matter the maximum/minimum value of the displayed chart and no matter the distance from all the other labels in the axis.
      Well, thanks for reading all this and i hope someone can help me, it is an urgent thing.
      Danilo
