6 Replies Latest reply on Aug 16, 2010 8:58 AM by grefel
    Replacing occurrences of a word by links
    BertrandRaphael
      Hello,
      I'm trying to write a Javascript script that would replace every occurrences of a given word in an Indesign CS3 document by a hyperlink pointing to a given URL.
      I'm very new to Indesign scripting, and I don't know where to start. I've tried searching this forum, but couldn't find the answer to my problem.
      If anyone can help...
      Bertrand
        • 1. Re: Replacing occurrences of a word by links
          grefel Level 2
          You could use my findAndDo Script (blog is in german): http://www.indesignblog.com/?p=7
          for a hyperlink you need to change it:
          app.changeGrepPreferences = NothingEnum.nothing;
          app.findGrepPreferences = NothingEnum.nothing;
          app.findGrepPreferences.findWhat = "SEARCH";
          var erg = app.activeDocument.findGrep ();
          for (var i = erg.length - 1; i >= 0; i--) {
              var _hlinkSource = app.activeDocument.hyperlinkTextSources.add(erg[i]);
              var _destination = app.activeDocument.hyperlinkURLDestinations.add("http://www.google.de");
              app.activeDocument.hyperlinks.add(_hlinkSource, _destination);
          • 2. Re: Replacing occurrences of a word by links
            BertrandRaphael Level 1
            Thank you very much Grefel! Your script works perfectly and creates hyperlinks for all the occurrences of my word.
            However there are two more things I need : I'd like the hyperlink object to be invisible, and the text occurrence to appear in blue.
            I figured I could make the links invisible by using the line
            app.activeDocument.hyperlinks.add(_hlinkSource, _destination).visible=false;
            But I'm not sure how I can make the text turn blue. I suppose I have to use apply some function to erg[i] within the loop, is that right?
            • 3. Re: Replacing occurrences of a word by links
              Best is to assign a character style on the links. Make one named "link", and specify your color in there. Then in the script, add this:
              erg[i].appliedCharacterStyle = app.activeDocuments.characterStyles.item("link");
              • 4. Re: Replacing occurrences of a word by links
                Excellent idea, thank you very much for all your help.
                • 5. Re: Replacing occurrences of a word by links
                  One problem with that script is that you can't run it a second time to update the URLs of the hyperlinks. If I do I get a message:
                  The object you have chosen is already in use by another hyperlink
                  It seems like the error is caused by the following line:
                  Is there a way to prevent that? For example, can the existing HyperlinkTextSource be removed? I couldn't find the existing  HyperlinkTextSource using app.activeDocument.hyperlinkTextSources.findByID( ), because I don't know its ID.
                  Is there a way to remove or update the hyperlink knowing just erg[i]?
                  • 6. Re: Replacing occurrences of a word by links
                    grefel Level 2
                    hey,
                    mmh, this looks more complex then expected. anyone out there who knows how to reference from a text object to a hyperlinkTextSource ???
                    you can solve it dirty this way:
                        // check for existing textSources:
                        var _hlinkSource = null;
                        var _allHlts = app.activeDocument.hyperlinkTextSources.everyItem().getElements();
                        for (m =0; m < _allHlts.length; m++) {
                            var _hlts = _allHlts[m];
                            if (_hlts.sourceText === erg[i]) {
                                _hlinkSource = _hlts;
                        // Only add if there is no textSource
                        if (_hlinkSource == null ) _hlinkSource = app.activeDocument.hyperlinkTextSources.add(erg[i]);
                        var _url =  "http://de.wikipedia.org/wiki/" + erg[i].contents
                        var _destination = app.activeDocument.hyperlinkURLDestinations.itemByName(_url);
                        // check if the destination already exists
                        if (_destination == null) app.activeDocument.hyperlinkURLDestinations.add(_url);
                        var _hlink = app.activeDocument.hyperlinks.add(_hlinkSource);
                        try {
                            _hlink.name = _url;
                        } catch (e) {}
                        _hlink.destination = _destination;
                    this code looks pretty ugly, because it checks every hyperlinkTextSource against the found text object.
                    another feasible way could be to remove all
                    hyperlinkTextSources, hyperlinkURLDestinations, hyperlinks
                    and run the script again.
                    anyway: i hope someone else has a more elegant solution.
