5 Replies Latest reply on Jul 17, 2010 7:29 PM by anovice45
    Text Box
    anovice45 Level 1
      When I place a text box and then try to resize it - it won't let me. I have to go to free transform and then it stretches/resizes the text. How do I fix this issue.
      Thanks in advance
        • 1. Re: Text Box
          Jacob Bugge MVP & Adobe Community Professional
          anovice,
          In order to be able to rearrange type by changing the box size, you will have to create it with the Area Type Tool associated with a path (such as a rectangle). Did you do that?
          • 2. Re: Text Box
            anovice45 Level 1
            No. I am using the type tool. I wanted to put some text on a flyer. I don't need it associated with it.
            I was under the assumption that you could resize the text box without it affecting the text inside.  Let's say I only had a narrow space for text but oversized my text box. I should be able to make it smaller but keep the same font size.
            • 3. Re: Text Box
              anovice,
              When you use the Type Tool, the type is an object unrelated to anything else; when you change the Font Size in the Character palette/panel, the type and its Bounding Box changes.
              If you wush to place the type inside a specific space, you must create a path corresponding to the space and then use the Type on Path Tool (clicking the path).
              The term Type implies that it is more than just text.
              • 4. Re: Text Box
                Steve Fairbairn Level 5
                Are you sure you've got a text box and not just a bounding box.
                The two look pretty much the same. Try turning off bounding boxes and see what happens.
                If what you have got IS indeed a text box, of course you can resize it without altering the size of the type.
                Do this with the direct selection tool.
                • 5. Re: Text Box
                  anovice45 Level 1
                  Thanks!
                  It was my text box that was showing and not the bounding box.
                  Works perfectly fine now!
                  Thanks again
