1 Reply Latest reply on Jul 18, 2010 4:19 AM by FM_Flame
    Flex 4 Fade effect reverse filter suspend ?
    FM_Flame Level 1
      Strigh to the point:
      I have a button which plays fade effect on a component. The fade effect looks like this:
      var fadeOut:Fade = new Fade();
      fadeOut.target = target;
      fadeOut.duration = 5000;
      fadeOut.alphaTo = 0;
      fadeOut.filter =
      "remove";
      fadeOut.captureStartValues();
      removeElement(target);
      fadeOut.play();
      Now I have a second button on which I have:
      fadeOut.reverse();
      The problem is that I want when the effect is reversed not to removeElement(target), but it still gets removed as soon as the effect ends. I tried on the second button fadeOut.filter = "", but no luck.
      So does anyone know how can I delete that filter so my element doesn't get removed when the effect is reversed and goes back to start state?
      Thanks !
        • 1. Re: Flex 4 Fade effect reverse filter suspend ?
          FM_Flame Level 1
          Probably there's a chance I might use this:
          mx.core.UIComponent.effectFinished(effectInst:IEffectInstance):void
          Called by the effect instance when it stops playing on the component. You can use this method to restore a modification to the component made by the effectStarted() method when the effect started, or perform some other action when the effect ends.
          But I don't seem to find any documentation on that, no examples no nothing, I don't understand how can i get that IEffectInstance and how am I supposed to restore the modifications to the component made by the effectStarted...
          Definitely need some help here...
