2 Replies Latest reply on Jul 19, 2010 8:38 AM by rtalton
    How to make a glow effect flash on/off
    iamcootis Level 1
      I am fairly new to effects and not sure exactly how they work. I would like to add a glow effect around an image and have it flash on and off to a timer. How would I make this happen? Thanks for your help.
      This is my glow effect:
      <mx:Glow id="glowImage"
              alphaFrom="1.0" alphaTo="0.3"
              blurXFrom="0.0" blurXTo="50.0"
              blurYFrom="0.0" blurYTo="50.0"
              color="green" duration="1000"/>
          <mx:Glow id="unglowImage" duration="1000"
              alphaFrom="0.3" alphaTo="1.0"
              blurXFrom="50.0" blurXTo="0.0"
              blurYFrom="50.0" blurYTo="0.0"
              color="green"/>
      Here is my image
      <mx:Image  id="checkMark" source="@Embed(source='assets/CheckMark.png')" visible="{showCheckMark}" />
        • 1. Re: How to make a glow effect flash on/off
          BhaskerChari Level 4
          Hi cootis,
          Check the below code which Flashes GlowEffect on and off based on the timer..
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
          layout="vertical"
          backgroundAlpha="0"
          backgroundColor="#FFFFFF"
          creationComplete="init()">
          <mx:Script>
            <![CDATA[
             private var timer:Timer = new Timer(1000, 2);
             private function init():void
              glowImage.target = checkMark;
              unglowImage.target = checkMark;
              timer.addEventListener(TimerEvent.TIMER_COMPLETE, onTimerComplete);
              timer.start();
              glowImage.play();
             private function onTimerComplete(event:TimerEvent):void
              timer.stop();
              timer.reset();
              timer.start();
              unglowImage.play();
             private function startGlowEffect():void
              glowImage.play();
          </mx:Script>
              <mx:Glow id="unglowImage" duration="1000" effectEnd="startGlowEffect();"
                  color="green"/>
          <mx:Image id="checkMark" source="@Embed(source='assets/Rose20Icon.jpg')" />
          </mx:Application>
          If this post answers your question or helps, please kindly mark it as such.
          Note: You can change the timer time to match your requirement to play the effect.
          I am playing the Glow effect as soon as the the UnGlow effect is finished...If you want to have a gap or start the GlowEffect on some button click..you just call startGlowEffect() function at that time instead.
          Bhasker Chari
          • 2. Re: How to make a glow effect flash on/off
            rtalton Level 4
            You an also check out Chet Haase's excellent blog on all things regarding effects.
            Here is a good example on how to animate the glow:
            http://graphics-geek.blogspot.com/search?q=glow
