13 Replies Latest reply on Jul 19, 2010 10:28 AM by efeelo
    Castmembers counting and display one by one on the stage
    efeelo
      I created a code to build lists of casts embers for display on the stage one by one and want to be able to use mouse click to move from cast member to cast member back and fort but I have difficulty getting this right. I have
      gotten index out of range error mostly. I had move the counter to various position but did not get it right.
      Does anyone have a suggestion?
        • 1. Re: Castmembers counting and display one by one on the stage
          efeelo Level 1
          This is the code I have custom written to do this, it list the first cast member and jumps to the last at some point with index out of range error.
          • 2. Re: Castmembers counting and display one by one on the stage
            Sean_Wilson Adobe Community Professional
            Please copy and paste your code into the editor here, not as a screenshot.
            • 3. Re: Castmembers counting and display one by one on the stage
              efeelo Level 1
              Hello Sean_Wilson
              Here is my custom codes:
              Global thewordnumber
              Global thewordcounter
              Global theword
              Global wordlist
              Global soundList
              Global wordCounter
              global thedefnumber
              global thedefcounter
              global defList
              global thedef
              global thepronunnumber
              global thepronuncounter
              global pronunList
              global thepronun
              global thecontextnumber
              global thecontextcounter
              global contextList
              global thecontext
              On BuildList
                thewordcounter = 1
                wordList = []
                soundList = []
                thedefcounter = 1
                defList = []
                thepronuncounter = 1
                pronunList = []
                thecontextcounter = 1
                contextList = []
                c = 250
                i = 1
                p = ""
                s = ""
                repeat while i <= c
                  if i < 10 then
                    p = "00" & i
                  else if i < 100 then
                    p = "0" & i
                  else
                    p = i
                  end if
                  add wordList, "word - " & p
                  add defList, "def - " & p
                  add pronunList, "pronun - " & p
                  add contextList, "context - " & p
                  add soundList, i
                  i = i + 1
                end repeat
                return wordList
                return defList
                return pronunList
                return contextList
                c = c + 1
              end
              On Mousedown me
                Buildlist
                wordCounter = 250
                thewordcounter = 1
                repeat while thewordcounter <= wordCounter
                  if thewordcounter < 251 then
                    thewordcounter = thewordcounter + 1
                    wordCounter = thewordcounter
                    thewordnumber = wordList[wordCounter]
                    theword = member(thewordnumber)
                    defCounter = thedefcounter
                    thedefnumber = defList[defCounter]
                    thedef = member(thedefnumber)
                    pronunCounter = thepronuncounter
                    thepronunnumber = pronunList[pronunCounter]
                    thepronun = member(thepronunnumber)
                    contextCounter = thecontextcounter
                    thecontextnumber = contextList[contextCounter]
                    thecontext = member(thecontextnumber)
                    set the member of sprite (2) = theword
                    set the member of sprite (3) = thepronun
                    set the member of sprite (4) = thedef
                    set the member of sprite (5) = thecontext
                    set the member of sprite (9) = thewordcounter
                  else
                    Alert "I am not doing what you want me to do"
                  end if
                end repeat
                return wordList
                return defList
                return pronunList
                return contextList
                wordCounter = wordCounter + 1
              end
              Thank you
              • 4. Re: Castmembers counting and display one by one on the stage
                While lists are a powerful and useful tool, I think you can get by without them in your case.
                Try the following behavior attached to your button:
                global gCurrentCounter
                on beginSprite me
                  gCurrentCounter = 1
                end
                on mouseUp me
                  if gCurrentCounter < 10 then
                    p = "00" & gCurrentCounter
                  else if gCurrentCounter < 100 then
                    p = "0" & gCurrentCounter
                  else
                    p = gCurrentCounter
                  end if
                  sprite(2).member = member("word - " & p)
                  sprite(3).member = member("def - " & p)
                  sprite(4).member = member("pronun - " & p)
                  sprite(5).member = member("context - " & p)
                  sprite(9).member.text = gCurrentCounter -- ??
                  if ( gCurrentCounter < 250 ) then gCurrentCounter = gCurrentCounter + 1
                end
                • 5. Re: Castmembers counting and display one by one on the stage
                  efeelo Level 1
                  Hello Saen_Wilson
                  Thank you for the suggested code, please tell me this:
                  why the question marks here?
                  If the counters become cast members, I can list and hopefully list them with
                  same statement such as this below?
                  sprite(9).member = member("counter - " & p).
                  Is there a better and simple formatted code for this?
                  Thanks.
                  efeelo.
                  • 6. Re: Castmembers counting and display one by one on the stage
                    The question marks were because I couldn't tell what you were trying to do. If there are cast members named like you suggest ("counter - " & p) then your code should work - try it and see.
                    • 7. Re: Castmembers counting and display one by one on the stage
                      efeelo Level 1
                      Hello Sean_Wilson
                      I used List and return functions because they bring all the associated
                      charisteistics listed in the fields together. With the counter, the sound
                      does not work. There are sounds associated with each field that I would like
                      to make sure they play.
                      So, just counting and moving through the casts does not  fulfil what I want
                      to do.
                      I hope you can help.
                      efeelo.
                      • 8. Re: Castmembers counting and display one by one on the stage
                        I saw your sound list declared and filled, but nowhere was there code dealing with playing it, so I figured the list was a left-over from a previous attempt that had been abandoned. What's more, your sound list is filled with integers - I have no way of knowing how you were going to use these to play sounds.
                        • 9. Re: Castmembers counting and display one by one on the stage
                          efeelo Level 1
                          There are buttons attached to the fronts of the fields with code such as
                          this:
                          On MouseDown me
                          Global soundList
                          Global wordCounter
                          sprt_sound=soundList[wordCounter]&"a"
                          Puppetsound 1, sprt_sound
                          end
                          • 10. Re: Castmembers counting and display one by one on the stage
                            So what about something like:
                            on mouseUp me
                              sSoundName = gCurrentCounter & "a"
                              sound(1).play(member(sSoundName))
                            end
                            • 11. Re: Castmembers counting and display one by one on the stage
                              efeelo Level 1
                              Hello Sean_Wilson
                              This does not work exactly the way it should since logically, the mouseup
                              handler is mostly what this react to. The logics really needs to be more
                              grounded than what we have so far in order for this to work properly.
                              Trying to to count forward and back, the logic is messing up.
                              Thanks.
                              efeelo.
                              • 12. Re: Castmembers counting and display one by one on the stage
                                efeelo Level 1
                                Your sugestions have been greatly motivating and very helpful. I have done,
                                thanks a lot.
                                • 13. Re: Castmembers counting and display one by one on the stage
                                  efeelo Level 1
                                  Hey Sean_Wilson, I mean we have done it. It is working very well, I figured
                                  out the sequence that will do exactly what I want it to do.
                                  Thank you again.
                                  efeelo.
