1 Reply Latest reply on Jul 19, 2010 8:59 AM by Rburn
    focusManager in FB4
    Rburn
      I moved a project created in flex 3 to FB4 and it works fine using sdk 3.5 If i set it to 4.1 sdk
      I get one error related to the focusManager.
      focusManager.moveFocus(mx.events.FocusRequestDirection.FORWARD);
      This command is used to move the cursor forward to the next tabindex in my application. Can someone help me out
      in what this has changed to? I know i've had isues with this in the 3 series sdk and it worked correctly i belive when sdk 3.3
      hit as it had a problem in mac versus pc. So in sdk 3.5 with air 2 it works correctly but changing sdk to 4.1 and trying (no compatibility mode or flex 3 compatibility mode) it errors on compile.
      Description    Resource    Path    Location    Type
      1061: Call to a possibly undefined method moveFocus through a reference with static type mx.managers:IFocusManager.    keyevent_functions.as    /BeamPro2/src    line 124    Flex Problem
      i have the following imports
      import mx.events.FocusRequestDirection;
      import mx.managers.FocusManager;
      import mx.managers.IFocusManager;
      import mx.managers.IFocusManagerComplexComponent;
      thanks for any help.
      Rob
