12 Replies Latest reply on Jul 20, 2010 4:41 AM by djh88ukwb
    Tree and view stack navigation
    djh88ukwb Level 1
      Hello all,
      I have the following Tree
          <fx:Declarations>
              <fx:XMLList id="navigation">
                  <node label="navigation">
                      <node label="Management 1">
                          <node label="Link one" view="View 1"/>
                          <node label="Link two" view="View 2"/>
                          <node label="Link three" view ="View 3"/>
                      </node>
                      <node label="Management 2">
                          <node label="Link one"/>
                          <node label="Link two"/>
                      </node>
                      <node label="Logout"/>
                  </node>
              </fx:XMLList>
          </fx:Declarations>
                  <mx:Tree id="navigationTree" width="100%" height="100%" labelField="@label" showRoot="false" dataProvider="{navigation}" contentBackgroundAlpha="0.0" color="#FFFFFF" borderVisible="false" y="10" change="treeChanged(event)"/>
      And the following viewstack
              <mx:ViewStack x="200" y="10" id="viewstack1" width="770" height="490" backgroundColor="#1c1c1c" cornerRadius="15" >
                  <s:NavigatorContent label="View 1" width="100%" height="100%">
                      <s:Label x="32" y="27" text="View One" color="#FFFFFF"/>
                  </s:NavigatorContent>
                  <s:NavigatorContent label="view 2" width="100%" height="100%">
                      <s:Label x="32" y="27" text="View Two" color="#FFFFFF"/>
                  <s:NavigatorContent label="view 3" width="100%" height="100%">
                      <s:Label x="32" y="27" text="View Three" color="#FFFFFF"/>
              </mx:ViewStack>
      Im struggling to create a function for the tree (change="TreeChanged(event)")  so that the view stack will change depending upon what item has been clicked.
      My xml has the view that is supposed to be shown but i cant link it all together, any help would be great !
        • 1. Re: Tree and view stack navigation
          djh88ukwb Level 1
          Nobody ?
          • 2. Re: Tree and view stack navigation
            rootsounds Level 4
            What part of this are you stuck on?
            • 3. Re: Tree and view stack navigation
              djh88ukwb Level 1
              I want the viewstack to change views depending upon what is clicked withint he tree . .
              • 4. Re: Tree and view stack navigation
                rootsounds Level 4
                Something along the lines of this:
                private function treeChange(event:ListEvent):void
                     var selectedNode:XML = XML(event.itemRenderer.data);
                     if ( selectedNode.hasOwnProperty("@view") ) //not all nodes have a view property, so check
                          //Either viewstack1.selectedIndex = selectedNode.@view assuming that you you store only indicies in @view
                          //OR viewstack1.selectedChild = this[@view] assuming that you give your NavigatorContent items ids and @view matches these ids. (don't be thrown by the array syntax)
                • 5. Re: Tree and view stack navigation
                  djh88ukwb Level 1
                  Hmm im having problems with this sorry.
                  Could you assume that my XML has teh value i want the viewstack to change to as "view"  so the funciton has to check the "view" label.
                  Also what "Imports" do i need to include? such as the
                              import mx.controls.Alert;
                              import mx.events.FlexEvent;
                              import mx.rpc.events.FaultEvent;
                  THanks for the help !
                  • 6. Re: Tree and view stack navigation
                    djh88ukwb Level 1
                    Nobody able to help me with this function ?
                    • 7. Re: Tree and view stack navigation
                      rootsounds Level 4
                      Go with this approach:
                                viewstack1.selectedChild = this[@view]; // assuming that you give your NavigatorContent items ids and @view matches these ids. (don't be thrown by the array syntax)
                      Your compiler will let you know if your are missing any imports.  The IDE (assuming that you are using one) should offer auto-complete to make adding them a breeze.
                      • 8. Re: Tree and view stack navigation
                        djh88ukwb Level 1
                        Thanks for your reply, however i get an error, stating
                        1120: Access of undefined property view.
                        Here is my complete code,
                        <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
                                               xmlns:mx="library://ns.adobe.com/flex/mx"   width="756" height="345">
                            <fx:Declarations>
                                            <node label="Link one" view="View1"/>
                                            <node label="Link two" view="View2"/>
                                            <node label="Link three" view ="View3"/>
                                        </node>
                                    </node>
                                </fx:XMLList>
                            </fx:Declarations>
                            <fx:Script>
                                <![CDATA[
                                    import mx.collections.ArrayCollection;
                                    import mx.events.ItemClickEvent;
                                    import mx.events.ListEvent;
                                    import mx.managers.PopUpManager;
                                    import mx.rpc.events.ResultEvent;
                                    import spark.events.IndexChangeEvent;
                                    import spark.events.TextOperationEvent;
                                    [Bindable]public var selectedNode:XML;
                            </fx:Script>
                            <mx:Tree id="navigationTree"  labelField="@label" showRoot="false" dataProvider="{navigation}" contentBackgroundAlpha="0.0" borderVisible="false" y="10" height="301" width="192" change="treeChange(event)"/>
                            <mx:ViewStack x="200" y="10" id="viewstack1" width="532" height="320" backgroundColor="#1c1c1c" cornerRadius="15" >
                                <s:NavigatorContent id="View1" width="100%" height="100%">
                                <s:NavigatorContent id="view2" width="100%" height="100%">
                                <s:NavigatorContent id="view3" width="100%" height="100%">
                            </mx:ViewStack>
                            <s:Label x="33" y="313" text="{selectedNode.@view}"/>
                        </s:WindowedApplication>
                        I know the selectedNode variable is holding the correct value, its just not changing the viewstack
                        Thanks !
                        • 9. Re: Tree and view stack navigation
                          rootsounds Level 4
                          Helps if I get it right:
                          viewstack1.selectedChild = this[selectedNode.@view];
                          • 10. Re: Tree and view stack navigation
                            djh88ukwb Level 1
                            Again thanks for the help !
                            However now when i run the desktop app, i get the following error when i try to change using the tree
                            ReferenceError: Error #1069: Property View2 not found on MyDesktopApp and there is no default value.
                                at MyDesktopApp/treeChanged()[C:\Users\Catherine Stewart\Adobe Flash Builder 4\Air Tests\src\MyDesktopApp.mxml:39]
                                at MyDesktopApp/__navigationTree_change()[C:\Users\Catherine Stewart\Adobe Flash Builder 4\Air Tests\src\MyDesktopApp.mxml:46]
                                at flash.events::EventDispatcher/dispatchEventFunction()
                                at flash.events::EventDispatcher/dispatchEvent()
                                at mx.core::UIComponent/dispatchEvent()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\co re\UIComponent.as:12266]
                                at mx.controls.listClasses::ListBase/mouseUpHandler()[E:\dev\4.0.0\frameworks\projects\frame work\src\mx\controls\listClasses\ListBase.as:10240]
                                at mx.controls::List/mouseUpHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cont rols\List.as:2469]
                                at mx.controls::Tree/mouseUpHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cont rols\Tree.as:3150]
                            :S looks nasty, any ideas what it is ?
                            • 11. Re: Tree and view stack navigation
                              rootsounds Level 4
                              Check the capitalization of your NavigatorContent ids.
                              • 12. Re: Tree and view stack navigation
                                djh88ukwb Level 1
                                Ahh Such a silly mistake,  Thanks !
