10 Replies Latest reply on Aug 16, 2010 10:12 AM by chris.campbell
    Find size of StorageVolume?
    balasubramaniyan.S
      Hi
      I can find spaceAvailable of StorageVolume using "storageVolume.rootDirectory.spaceAvailable".
      Is it possible to find size of StorageVolume?
      Bala.S
        • 1. Re: Find size of StorageVolume?
          thilgen Level 4
          Bala.S
          This is not currently supported - but is a great idea.
          Could you please log a feature request at: http://ideas.adobe.com/air/
          Chris Thilgen
          AIR Engineering
          • 2. Re: Find size of StorageVolume?
            balasubramaniyan.S Level 1
            Hi
            Posted idea in Adobe AIR Ideas.
            I can find file size using FileRefrence. But how can convert File object to FileRefrence object. Is FileRerfrence use only for upload/download? After browse only i can find size for selected file. Is it possible to assign file without browse to the Filerefrence object. How!!!???
            Bala.S
            • 3. Re: Find size of StorageVolume?
              thilgen Level 4
              File inherits from FileReference - so a File is a FileReference.
              Yes, FileReference is only used for upload/download. But File objects can be created/used at any time (in AIR).
              You can create a new File object in a variety of ways
              1) passing a local path to the constructor
                var f:File = new File("c:\\test.text");
              2) using relative paths (better cross-platform solution)
                var f:File = File.documentsDirectory.resolvePath("test.txt");
              Please refer to the AS3 reference for the File object for additional information:
              http://livedocs.adobe.com/flash/9.0/ActionScriptLangRefV3/flash/filesystem/File.html#File()
              Hope this helps.
              Chris Thilgen
              AIR Engineering
              • 4. Re: Find size of StorageVolume?
                Thanks for your reply,
                I already know about passing local path and relative path.
                I want to get size of the file directory. How can i get it?
                I think not possible. Is it correct?
                Regards
                Bala.S
                • 5. Re: Find size of StorageVolume?
                  lisachao Adobe Employee
                  Would this work?
                  import flash.filesystem.StorageVolumeInfo;
                  import flash.filesystem.StorageVolume;
                  import flash.filesystem.File;
                  import flash.events.StorageVolumeChangeEvent;
                  public function mountEvtHandler(mountEvt:StorageVolumeChangeEvent):void {
                     var mountedVolume:StorageVolume = mountEvt.storageVolume;
                     var fileHandle:File = mountEvt.rootDirectory;
                     var spaceAvailableString:String = fileHandle.spaceAvailable.toString();
                  • 6. Re: Find size of StorageVolume?
                    i know how to get space Available, but i need to find total size.
                    • 7. Re: Find size of StorageVolume?
                      What about this?
                      import flash.system.Capabilities;
                      private function getDrives():void
                            var os:String = Capabilities.os.substr(0, 3).toLowerCase();
                            var currentDrives:Array = (os=="mac") ? new File('/Volumes/').getDirectoryListing() : File.getRootDirectories() ;
                            for each(var file:File in currentDrives){
                                trace ("Drive: " + file.name + " Size: " + file.size);
                      • 8. Re: Find size of StorageVolume?
                        tonysilvestri
                        Similar to the post before me:
                                public function determineIfSpaceIsAvailable(e:SpaceAvailableEvent) : void{
                                    var volumes : Vector.<StorageVolume> = StorageVolumeInfo.storageVolumeInfo.getStorageVolumes();
                                    for each (var volume:StorageVolume in volumes)
                                        if(volume.isRemovable && volume.isWritable){
                                            checkSpace(volume);
                                            break;
                                        } else if(volumes.lastIndexOf(volumes)){
                                            var event:ThumbDriveNotFoundEvent = new ThumbDriveNotFoundEvent(ThumbDriveNotFoundEvent.THUMB_DRIVE_NOT_FOUND);
                                           dispatcher.dispatchEvent( event );
                                private function checkSpace(_currentVolume : StorageVolume):void{
                                    var vol : StorageVolume = _currentVolume;
                                    var spaceAvailable = vol.rootDirectory.size;
                        in my case I needed to know the space available on a thumb drive.  This is how I did it....
                        • 9. Re: Find size of StorageVolume?
                          It works. Is the size return in bytes?
                          • 10. Re: Find size of StorageVolume?
                            chris.campbell Adobe Employee
                            Moved discussion to the Adobe AIR Development forum
