1 Reply Latest reply on Jan 14, 2011 11:54 AM by scooby_11
    Implementing a nested block diagram
    Sen Imagines Level 1
      I would like to draw a block diagram ( as shown in the below image )
      The text on the blocks would be fetched from a well structured XML file.
      If there is a node of type: A in the XML, corresponding green box, say A1 should be drawn and the a horizontal line should be added to connect the end blue box (Gp4)
      Similarly, if there is a node of type: B in the XML, corresponding orange box, say B1 should be drawn and a vertical line should be added to connect the bottom (O/p B) box and the top box (Gp B)
      Similarly, if there is a node of type: C in the XML, corresponding yellow box, say C1 should be drawn and a vertical line should be added to connect the bottom (O/p C) box
      What is the best & easier way to implement this diagram ( HTML, Flash, Flex ) ?
      -  Sen.
