3 Replies Latest reply on Jul 22, 2010 2:48 AM by CHMprepress
    Export to Psd flattens layers with overprint
    enter a nickname Level 1
      So, if Illustrator flattens all the layers below anything with overprint, how am I supposed to make a layered cmyk .PSD file with overprint type?  The only solutions  I can see are:
      1) To pick out every layer of type in the photoshop file and set it to multiply.
      2) To make multiple exports and then combine them in photshop.
      Is there a better method?
      And is there any way to export layers with the overprint? And then finally , what IS the best way to export to photoshop in cmyk?
        • 1. Re: Export to Psd flattens layers with overprint
          CHMprepress Level 3
          Why export to Photoshop?
          Why dont you setup your elements right in Illustrator. Now with the transparanties and effects in Illustrator no need annymore to step to Photoshop.
          • 2. Re: Export to Psd flattens layers with overprint
            You are right in suggesting that I simply send clients a properly layered .ai or .pdf file. But there are a couple of reasons I don't usually do this:
            First, both me and some clients worry that they can mess up the file.
            And second many if not most clients prefer this as just plain simpler- no worry about fonts and all that.
            It surprises me how many major publishers prefer images as tiffs. The reason for this, I suppose is that most of their images are raster-based and its relatively rare to get something else. Then, they always worry about fonts.
            The printers are always left to figure out the screwed-up messes we provide and they (almost) always fix it in the end. I wrote this question so that maybe a printer or a pre-press expert could steer me a little. save us both some work and provide a better product.
            • 3. Re: Export to Psd flattens layers with overprint
              CHMprepress Level 3
              Wel fonts should not be a problem annymore, if you export your pdf as it should be, fonts aar embeded. A other option is to deliver a vectorised pdf.
