0 Replies Latest reply on Jul 19, 2010 1:48 PM by sleblang
    Issue with two way bindings in states
    sleblang Level 1
      I have found that if I try to use two way bindings on a property that is specific to a state, i.e. textfield text property, the two way binding does not work. Here's an example:
      <s:states>
           <s:State name="normal"/>
           <s:State name="details"/>
      </s:states>
      [Bindable]
      private var bindingTest:String = "This is a test of two way bindings";
      <s:TextArea x="224" y="438" width="667" height="54" id="notes_txt" text.details="@{bindingTest}" />
      If I change the TextArea's text property, the property, bindingTest should update. However, this does not seem to work as outlined above. However, if you simply change text.details="@{bindingTest}" to text="@{bindingTest}" then two way binding works. Is this by design?
      Thanks for any and all replies.
