10 Replies Latest reply on Jul 21, 2010 12:42 PM by kglad
    count
    Ron Colmen Level 2
      on frame 1 I've got 10 movieclips and each movieclip has a toggle button to make it visible true and false.
      How do write the script to do the following on frame 10?
      if only 1 movieclip is visible make one_mc visible true
      if only 2 movieclips are visible make two_mc visible true
      if only 3 movieclips are visible make three_mc visible true
      ... so on for all 10 hope this make sense.
        • 1. Re: count
          loop through your movieclips and total the number whose visible property is true.
          • 2. Re: count
            Ron Colmen Level 2
            thanks. could you show me a sample.
            • 3. Re: count
              Ron Colmen Level 2
              this is what i managed to do so far.... help me with the coding.
              _root.ldrpdf20_mc._visible=false;
              _root.ldrpdf40_mc._visible=false;
              _root.sender_mc.sender.onRelease = function () {
              var myvis = ["one_outline", "two_outline", "three_outline", "four_outline", "five_outline", "six_outline"];
              var myvis:Number=0;
              //for (i=0; i<myvis.length ; i++){
              myvis++;
              if(myvis==1){
              _root.ldrpdf20_mc._visible=true;
              myvis++;
              if(myvis==2){
              _root.ldrpdf40_mc._visible=true;
              • 4. Re: count
                use:
                var mcA:Array = [_root.ldrpdf20_mc,__root.ldrpdf40_mc, etc..];
                var myvisA:Array = ["one_outline", "two_outline", "three_outline", "four_outline", "five_outline", "six_outline"];
                var visNum:Number=0;
                for (i=0; i<mcA.length ; i++){
                if(mcA[i]._visible){
                visNum++
                myvisA[visNum]._visible=true;
                • 5. Re: count
                  Ron Colmen Level 2
                  Thanks kglad. but the code dosen't seem to respond. This did not pick the correct movieclip... it always shows the "ldrpdf20_mc". I also tried by adding if(myvisA[i]._visible==true) but still no success.
                  example of what i want to achieve: if "one_outline", "three_outline", "six_outline" are visible then make ldrpdf60_mc visible.
                  on frame 10:
                  var mcA:Array = [_root.ldrpdf20_mc,_root.ldrpdf40_mc,_root.ldrpdf60_mc,_root.ldrpdf80_mc,_root.ldrpdf100_ mc,_root.ldrpdf120_mc];
                  for (i=0; i<myvisA.length ; i++){
                  if(myvisA[i]._visible==true){
                  visNum++
                  mcA[visNum]._visible=true;
                  Thank you!
                  • 6. Re: count
                    myvisA should be an array of movieclips, not strings:
                    var mcA:Array = [_root.ldrpdf20_mc,_root.ldrpdf40_mc,_root.ldrpdf60_mc,_root.ldrpdf80_mc,_root. ldrpdf100_mc,_root.ldrpdf120_mc];
                    var myvisA:Array = [one_outline, two_outline, three_outline, four_outline, five_outline, six_outline];
                    visNum++
                    • 7. Re: count
                      Ron Colmen Level 2
                      Thank you kglad.
                      also how do I say do this if visNum=0
                      blank_mc._visible=false;
                      var myvisA:Array = [one_outline,two_outline,three_outline,four_outline,five_outline,_six_outline];
                      visNum++
                      if(visNum==0){
                      blank_mc._visible=true
                      • 8. Re: count
                        use:
                        var mcA:Array = [blank_mc,_root.ldrpdf20_mc,_root.ldrpdf40_mc,_root.ldrpdf60_mc,_root.ldrpdf80_mc,_root. ldrpdf100_mc,_root.ldrpdf120_mc];
                        visNum++
                        if(visNum==0){
                        • 9. Thanks!
                          Ron Colmen Level 2
                          Thank you! I wish i could give you more than 20.
                          • 10. Re: Thanks!
                            you're welcome.
