4 Replies Latest reply on Nov 28, 2010 11:45 PM by nico4280
    Data push in flex
    aruvasavi
      Hi
      I am working on data push in flex!
      I am using consumer component in flex to subscribe to server to receive the data push by it!
      Data push is happening for sometime and when I switch to other browsers and come back consumer is not listening to the data sent by server but I can see the logs in the server. let me know any poitnters regarding this?
      Find the piece of code below...
      <mx:Consumer
      id="cameraControlConsumer" destination="deviceDataFeeder"
      message="messageHandlerForCameraControl(event)" fault="faultHandler(event)"
      private
      function faultHandler(event:MessageFaultEvent):
      void
      Alert.show(event.message.faultString);
      private function messageHandlerForCameraControl(event:MessageEvent):void {
      var msgSender:String = event.message.headers["USR_LOGIN_ID"].toString();
      if (msgSender == myModel.loginUserId.toString()) {
      tempObj =
      new ObjectMap(event.message.body as Object);
      tempMap = tempObj.getHashMap();
      if (null != tempMap) {
      var tempVar:String = tempMap.getValue("vmsDeviceId");
      if(tempVar != null) {
      selectedCameraId = tempVar;
      else {
      selectedCameraId =
      null;
      if (1 != getStatus(selectedCameraId)&& selectedCameraId != null)
      disableCameraControl(
      false);
      tempVar = tempMap.getValue(
      "MdviZoomMax");
      if(tempVar != null)
      maximumZoom = int(tempVar);
      "MdviZoomMin");
      if(tempVar != null)
      minimumZoom = int(tempVar);
      else {
      true);
      Thanks and Regards
      Aruna.S.N.
        • 1. Re: Data push in flex
          nico4280
          Hello,
          I've got a similar problem.
          Sometime consumer stop listening to the data sent by server. However, I can see data are OK in the "MessageService.pushMessageToClients" function.
          Did you find a solution to your problem?
          Can anyone help?
          Nicolas
          • 2. Re: Data push in flex
            aruvasavi Level 1
            Hi
            Yes the the most bugging problem, took lot of time to debug this.
            check web.xml file in your server, need to set session time out property as below
              <!-- Set timeout to 120 minutes -->
                    <session-config>
                            <session-timeout>120</session-timeout>
                    </session-config>
            Thanks and Regards
            Aruna.S.N
            • 3. Re: Data push in flex
              aruvasavi Level 1
              Hi
                      <session-config>
                      </session-config>
              Set '-1' for session to be continuous...
              Thanks and Regards
              Aruna.S.N
              • 4. Re: Data push in flex
                nico4280 Level 1
                I will try this.
                Thanks for responding.
                Nicolas
