1 Reply Latest reply on Jul 26, 2010 3:02 AM by Vikranth p vivek
    Skin import/export and XML issue? Cp5
    shanieliraz
      Hello there,
      I have to say I'm feeling rather stupid posting again and again -- there is a team of us working from a central repository and due to deadlines, we had a couple of projects started before we finalised a template.
      Now that we have a template, it seems extremely difficult to apply the designed skin onto the existing project. Even though I saved the template skin, I could not find it's source file and none of the export fundtions actually facilitates the skin definitions.
      I tried opening the project on the machine on  which the skin was designed assuming I could choose it from the drop  down selection - but - alas - even though it was saved, it was no where  on that list.
      By pure fluke, I had the template and the working project open at the same time and found out I could then - and only then - choose the skin from the template when changing skin settings for the proejct.
      Is this how it's meant to happen, or am I missing something huge?....
      Also - having attempted a number of times to export settings via XML and re-importing them straight back in (on the same machine using the same template/project file), the importing of the XML file fails every single time.
      I wouldn't mind attaching it in case it needs reviewing, however, I did not edit/reqrite anything from it's Captivate output, nor can I find a means of attaching files to this forum....
      Not my day, is it?!
      Thanks for your help, shani.
        • 1. Re: Skin import/export and XML issue? Cp5
          Vikranth p vivek Level 2
          The skin gets saved in the preferences folder.
          If you have created a custom skin and saved it, then it will be saved as .ini file in the Captivate Preferences folder.
          (C:\Documents and Settings\User\Local Settings\Application Data\Adobe\Captivate 5\Themes assuming you have installed captivate in C:\ directory)
          Each time captivate launches, it retrieves all the saved skins from this folder.
          So, if there is any custom saved skin then it should get listed in the Skin Editor >> Skin drop down irrespective of the project in which it was created.
          Regards,
          Vikranth.
