2 Replies Latest reply on Jul 20, 2010 8:29 AM by heroicjanitor
    remoting help
    heroicjanitor Level 1
      I am using flex with a java back end, my test application is just a button that when i press it displays a string from a java class called HelloSayer. It works fine but when I change it to a different class(and give the remoting-config.xml a new destination) where I want it to return a tweet from a java class it fails and I think it is something to do with my xml, possibly the scope. I'd be grateful if someone could have a look through this since I am very new to flex and remoting.
      Here is the class when it works:
         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
      <fx:Script>
      <![CDATA[
      import mx.controls.Alert;
      import mx.rpc.AsyncToken;
      import mx.rpc.Responder;
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.remoting.RemoteObject;
      protected function callJava(event:MouseEvent):void
      var javaObject : RemoteObject = new RemoteObject("hello");
      var token : AsyncToken = javaObject.sayHello();
      token.addResponder(new mx.rpc.Responder(handleResult, handleFault));
      private function handleResult(event : ResultEvent) : void {
      Alert.show(event.result.toString());
      private function handleFault(event : FaultEvent) : void {
      Alert.show(event.fault.message);
      </fx:Script>
      <s:Button x="280" y="230" label="Contact Java" click="callJava(event)"/>
      </s:Application>
      And the xml:
      <?xml version="1.0" encoding="UTF-8"?>
      <service id="remoting-service"
          class="flex.messaging.services.RemotingService">
          <adapters>
              <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
          </adapters>
          <default-channels>
              <channel ref="my-amf"/>
          </default-channels>
      <destination id="hello">
                 <properties>
                     <source>test.HelloSayer</source>
                     <scope>application</scope>
                 </properties>
           </destination>
      </service>
      but when i change callJava to this:
      var javaObject : RemoteObject = new RemoteObject("tweets");
      javaObject.setTweets(username, password); // tells java the username/password so it can make a list of tweets
      var token : AsyncToken = javaObject.getTweets(2); // This just returns the second tweet in the list as a string
      And add a destination in the xml like this:
      <destination id="tweets">
                 <properties>
                     <source>twitter.Tweets</source>
                 </properties>
           </destination>
      It gives me loads of errors.
      When I click the button it says:
      faultCode:Client.Error.MessageSend faultString:'Send failed' faultDetail:'Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 404: url: 'http://localhost/TestCombo/messagebroker/amf''
      And when I look in the console window it says
      [BlazeDS]Error instantiating application scoped instance of type 'twitter.Tweets' for destination 'tweets'.
      java.lang.NoClassDefFoundError: twitter4j/TwitterException
      at java.lang.Class.forName0(Native Method)
      at java.lang.Class.forName(Unknown Source)
      at flex.messaging.util.ClassUtil.createClass(ClassUtil.java:61)
      at flex.messaging.factories.JavaFactoryInstance.getInstanceClass(JavaFactoryInstance.java:11 0)
      at flex.messaging.factories.JavaFactoryInstance.createInstance(JavaFactoryInstance.java:96)
      at flex.messaging.factories.JavaFactory.createFactoryInstance(JavaFactory.java:114)
      at flex.messaging.FactoryDestination.createFactoryInstance(FactoryDestination.java:252)
      at flex.messaging.FactoryDestination.getFactoryInstance(FactoryDestination.java:235)
      at flex.messaging.FactoryDestination.getFactoryInstance(FactoryDestination.java:223)
      at flex.messaging.services.remoting.adapters.JavaAdapter.validateInstanceSettings(JavaAdapte r.java:549)
      at flex.messaging.services.remoting.adapters.JavaAdapter.start(JavaAdapter.java:360)
      at flex.messaging.Destination.start(Destination.java:256)
      at flex.messaging.services.AbstractService.startDestinations(AbstractService.java:650)
      at flex.messaging.services.AbstractService.start(AbstractService.java:173)
      at flex.messaging.MessageBroker.startServices(MessageBroker.java:1426)
      at flex.messaging.MessageBroker.start(MessageBroker.java:353)
      at flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:146)
      at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper.java:1172)
      at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:992)
      at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContext.java:4058)
      at org.apache.catalina.core.StandardContext.start(StandardContext.java:4371)
      at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
      at org.apache.catalina.core.StandardHost.start(StandardHost.java:719)
      at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443)
      at org.apache.catalina.core.StandardService.start(StandardService.java:516)
      at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
      at org.apache.catalina.startup.Catalina.start(Catalina.java:578)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:288)
      at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
      Caused by: java.lang.ClassNotFoundException: twitter4j.TwitterException
      at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1387)
      at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1233)
      ... 34 more
      [BlazeDS]MessageBroker failed to start:   Exception: flex.messaging.config.ConfigurationException: Error instantiating application scoped instance of type 'twitter.Tweets' for destination 'tweets'.
      at flex.messaging.factories.JavaFactory.createFactoryInstance(JavaFactory.java:144)
      Caused by: java.lang.NoClassDefFoundError: twitter4j/TwitterException
      ... 28 more
      ... 34 more
      **** MessageBrokerServlet failed to initialize due to runtime exception:   Exception: java.lang.RuntimeException: Error instantiating application scoped instance of type 'twitter.Tweets' for destination 'tweets'.
      at flex.messaging.MessageBroker.start(MessageBroker.java:365)
      Caused by: flex.messaging.config.ConfigurationException: Error instantiating application scoped instance of type 'twitter.Tweets' for destination 'tweets'.
      ... 18 more
      ... 28 more
      ... 34 more
      20-Jul-2010 13:33:53 org.apache.catalina.core.ApplicationContext log
      INFO: Marking servlet MessageBrokerServlet as unavailable
      20-Jul-2010 13:33:53 org.apache.catalina.core.StandardContext loadOnStartup
      SEVERE: Servlet /TestCombo threw load() exception
      javax.servlet.UnavailableException: Error instantiating application scoped instance of type 'twitter.Tweets' for destination 'tweets'.
      at flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:170)
      If there is anything else anyone needs to see just ask because this is really confusing me
