3 Replies Latest reply on Jul 21, 2010 4:22 AM by hspan
    _movie.go() onhyperlinkclicked
    hspan
      Hi
      I have different movies in a folder and I want to create hyperlinks to switch between them. I'm using the following statement for the jump:
      _movie.go("01","chap1_10")
      Now whenever I click on the links, jump occurs, but the projector crashes immediately. The same works fine in case of onMouseUp event on a member (which I can not use in my case).
      I googled and came around some info such as its really a bug and it used to work fine in earlier versions. Is there any way or workaround to accomplish this? Any help is greatly appreciated.
        • 1. Re: _movie.go() onhyperlinkclicked
          Production Monkey Level 3
          Wow!!  I couldn't believe there was a bug with your code so I tried it out. Unbelievable..
          When I run into this class of bug the first thing I try is to delay the action I want to take by using a timeout object. I tried that and it works.
          This behavior works for me in D11.5
          property  pClicked
          property  pData
          on hyperlinkClicked me, data, range
            if pClicked then exit  -- stop multiple clicks
            pClicked = 1
            pData = data
            Tmp = timeout().new("goMovieDelay", 1, #goToMovie , me)
          end
          on goToMovie me, Timeob
            Timeob.forget()
            go(1,pData)
          end
          Randal.
          • 2. Re: _movie.go() onhyperlinkclicked
            Sean_Wilson Adobe Community Professional
            This is a known problem with many asset xtras:  jumping to a frame/movie that will destroy the sprite instance from an event generated by the sprite causes a crash. This was an issue in the Text Asset some years ago and was subsequently fixed. It's unfortunate it has re-appeared.
            • 3. Re: _movie.go() onhyperlinkclicked
              hspan Level 1
              Hi
              I tried your method and it worked like a charm .
              Thanks a lot for your help.
