4 Replies Latest reply on Jul 20, 2010 4:47 PM by Flex harUI
    Simple SharedObject question (I think)
    jeffcg2 Level 1
      I am trying to understand how to write and read from the SharedObject to remember a login.
      This was simple in Flex Builder 3, used the wizard and it built the login plumbing whether you wanted it or not.
      I tried to get something from the video below, but obviouly there is more.
      I run the code below and get:
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at logtest/saveData()[C:\Inetpub\wwwroot\tiptest\src\logtest.mxml:26]
      at logtest/___logtest_Button1_click()[C:\Inetpub\wwwroot\tiptest\src\logtest.mxml:48]
      The sharedobject is null.
      What am I not understanding.
      http://tv.adobe.com/watch/adc-presents/using-shared-objects-in-flex-applications
      <s:Application
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
      <s:layout>
      <s:BasicLayout/>
      </s:layout>
      <fx:Script>
      <![CDATA[
      import flash.net.SharedObject;
      private var sharedObj:SharedObject;
      private function initSharedObject():void
      SharedObject.getLocal(
      "myContacts" );
      if ( sharedObj.size > 0 )
      txtArea.text = sharedObj.data.contacts;
      private function saveData(event:MouseEvent):void
      sharedObj.data.contacts = txtInput.text;
      sharedObj.flush();
      lbl.text =
      "Data Stored Locally";
      private function deleteData(event:MouseEvent):void
      sharedObj.clear();
      lbl.text =
      "Local Data Deleted";
      </fx:Script>
      <fx:Declarations>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <s:TextArea x="268" y="120" id="txtArea"/>
      <s:Label id="lbl" x="268" y="279" width="161">
      </s:Label>
      <s:Button x="160" y="341" label="Save" click="saveData(event)"/>
      <s:Button x="249" y="341" label="Delete" click="deleteData(event)"/>
      <s:Button x="344" y="341" label="Button"/>
      <s:TextInput x="268" y="68" id="txtInput"/>
      </s:Application>
        • 1. Re: Simple SharedObject question (I think)
          Flex harUI Adobe Employee
          I don't think I saw a call to initSharedObject or storing of the
          SharedObject in the sharedObject property
          • 2. Re: Simple SharedObject question (I think)
            rtalton Level 4
            It looks like your LSO is null because you have not populated it yet with the initSharedObject() method.
            Try calling initSharedObject() from the creationComplete event of the application.
            • 3. Re: Simple SharedObject question (I think)
              jeffcg2 Level 1
              I added the creation complete and get this error now. I don't know what you mean by "storing of the Shared Object in the sharedObject property"
              <s:Application
              xmlns:s="
              xmlns:mx="
              creationComplete="initSharedObject()"
              at logtest/initSharedObject()[C:\Inetpub\wwwroot\tiptest\src\logtest.mxml:19]
              at logtest/___logtest_Application1_creationComplete()[C:\Inetpub\wwwroot\tiptest\src\logtest .mxml:5]
              at flash.events::EventDispatcher/dispatchEventFunction()
              at flash.events::EventDispatcher/dispatchEvent()
              at mx.core::UIComponent/dispatchEvent()[E:\dev\4.x\frameworks\projects\framework\src\mx\core \UIComponent.as:12528]
              at mx.core::UIComponent/set initialized()[E:\dev\4.x\frameworks\projects\framework\src\mx\core\UIComponent.as:1627]
              at mx.managers::LayoutManager/doPhasedInstantiation()[E:\dev\4.x\frameworks\projects\framewo rk\src\mx\managers\LayoutManager.as:759]
              at mx.managers::LayoutManager/doPhasedInstantiationCallback()[E:\dev\4.x\frameworks\projects \framework\src\mx\managers\LayoutManager.as:1072]
              • 4. Re: Simple SharedObject question (I think)
                sharedObj = SharedObject.getLocal( "myContacts" );
