2 Replies Latest reply on Jul 20, 2010 11:36 PM by NewFlo
    ArrayCollection dataprovider
    docwisdom
      I am having a little problem populating a datagrid with an array collection. Thought maybe someone could help.
      I have this remoteobject code and accompanying AS code.
      <s:RemoteObject id="serviceEditTicket" destination="ColdFusion" source="prism.cfc.serviceEditTicket" showBusyCursor="true">
      <s:method name="getOpenTicketsByTicketID" result="getOpenTicketsByTicketID_result(event);">
      <s:arguments>
      <tkid>
      </tkid>
      </s:arguments>
      </s:method>
      </s:RemoteObject>
      [Bindable]
      private var getEditTicket:ArrayCollection;
      private function getOpenTicketsByTicketID_result(event:ResultEvent):void
      getEditTicket = event.result.qGetOpenTicketsByTicketID as ArrayCollection;
      I then use getEditTicket as my dataprovider in the datagrid. Nothing seems to populate. When I debug, the ArrayCollection never gets populated in the variables panel.
      On the other hand, If I use serviceEditTicket.getOpenTicketsByTicketID.lastResult the datagrid populates just fine.
      What do you think I am doing wrong here?
        • 1. Re: ArrayCollection dataprovider
          Subeesh Arakkan Level 4
          Check if you are getting an Array as result instead of ArrayCollection. If you are getting an Array, you need to create a new ArrayCollection from the Array. Something like this
          getEditTicket = new ArrayCollection(event.result.qGetOpenTicketsByTicketID as Array);
          • 2. Re: ArrayCollection dataprovider
            NewFlo
            If you are sure your datafield-properties (at the datagrid columns) are set correctly, use the debug-Mode (if you are using Flex/Flashbuilder) to check the result-object. It happend to me that the arraycollection i wanted was one level down in the result-object like event.result.result. Also add eventlisteners for all errors and/or error-events so you don't miss an error during runtime. You can also use a sniffer like (http://www.charlesproxy.com/) to check your remote-call. At least this are things i often forget, so maybe it helps finding the problem.
            all the best
