2 Replies Latest reply on Jul 27, 2010 7:44 AM by PegasusT4
    Errors in Logfile on CFB Startup
    PegasusT4 Level 1
      Every time I start CFB I get the following error in the log file. Running CFB standalone with latest update on WinXP sp3. Also happens  with Win 7 too.
      Any ideas what is causing this on my systems and is it really important? CFB seems to run ok otherwise although it does occasionally slow way down to a crawl.
      Doug
      Unhandled event loop exception.  ... org.eclipse.ui
      !SESSION 2010-07-20 22:31:47.812 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.6.0_18
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86 -clean
      !ENTRY org.eclipse.equinox.ds 4 0 2010-07-20 22:31:53.796
      !MESSAGE
      !STACK 0
      org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Import-Package: org.eclipse.equinox.internal.util.event; version="1.0.0"
          at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.j ava:1313)
          at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(Abs tractBundle.java:1297)
          at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:309)
          at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:370)
          at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1068)
          at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManage r.java:557)
          at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java :464)
          at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelMana ger.java:248)
          at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManage r.java:445)
          at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
          at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
      !ENTRY org.eclipse.help 4 0 2010-07-20 22:32:22.484
      !MESSAGE Error reading help table of contents file /"com.extjs.ext.3.0/docs/docs/index.xml" (skipping file)
      !STACK 0
      java.io.FileNotFoundException
          at org.eclipse.help.internal.toc.TocFileParser.parse(TocFileParser.java:45)
          at org.eclipse.help.internal.toc.TocFileProvider.getTocContributions(TocFileProvider.java:45 )
          at org.eclipse.help.internal.toc.TocManager.getAndCacheTocContributions(TocManager.java:205)
          at org.eclipse.help.internal.toc.TocManager.getTocContributionsForToc(TocManager.java:194)
          at org.eclipse.help.internal.toc.TocManager.getRootTocContributions(TocManager.java:298)
          at org.eclipse.help.internal.toc.TocManager.getTocs(TocManager.java:67)
          at org.eclipse.help.internal.toc.TocManager.getTopic(TocManager.java:118)
          at org.eclipse.help.internal.toc.TocManager.getTopicPath(TocManager.java:133)
          at org.eclipse.help.internal.webapp.data.UrlUtil.getTopicPath(UrlUtil.java:179)
          at org.eclipse.help.internal.webapp.servlet.BreadcrumbsFilter.filter(BreadcrumbsFilter.java: 74)
          at org.eclipse.help.internal.webapp.servlet.EclipseConnector.transfer(EclipseConnector.java: 165)
          at org.eclipse.help.internal.webapp.servlet.ContentServlet.doGet(ContentServlet.java:42)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
          at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletM anager.java:180)
          at org.eclipse.equinox.http.servlet.internal.ServletRegistration.handleRequest(ServletRegist ration.java:90)
          at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:111 )
          at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:67)
          at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.serv ice(HttpServerManager.java:318)
          at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:502)
          at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:380)
          at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
          at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
          at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
          at org.mortbay.jetty.Server.handle(Server.java:324)
          at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:535)
          at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:865)
          at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:540)
          at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:213)
          at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
          at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
          at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:520)
      !ENTRY org.eclipse.ui 4 0 2010-07-20 22:32:36.453
      !MESSAGE Unhandled event loop exception
      !STACK 0
      org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
          at org.eclipse.swt.SWT.error(SWT.java:3884)
          at org.eclipse.swt.SWT.error(SWT.java:3799)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
          at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.ide.coldfusion.rcp.intro.Application.start(Unknown Source)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:597)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
      Caused by: java.lang.NullPointerException
          at org.eclipse.eclipsemonkey.actions.RecreateMonkeyMenuAction.createTheMenu(RecreateMonkeyMe nuAction.java:118)
          at org.eclipse.eclipsemonkey.actions.RecreateMonkeyMenuAction.run(RecreateMonkeyMenuAction.j ava:71)
          at org.eclipse.eclipsemonkey.UpdateMonkeyActionsResourceChangeListener$2.run(UpdateMonkeyAct ionsResourceChangeListener.java:256)
          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
          ... 22 more
        • 1. Re: Errors in Logfile on CFB Startup
          hemant_k Employee Moderator
          Just want to confirm if you are running on latest update - http://www.adrocknaphobia.com/post.cfm/coldfusion-builder-update-1-available
          Can you log a bug with the stacktrace? http://cfbugs.adobe.com
          • 2. Re: Errors in Logfile on CFB Startup
            PegasusT4 Level 1
            Yes, I'm running Update 1 CFB 1.0.0.274293. I've uninstalled and reinstalled CFB and still have the same problem. In fact now I also get other errors about Aptana documentation and other stuff.
            Doug
            Error
            Tue Jul 27 10:34:18 EDT 2010
            Category com.aptana.ide.documentation not found for view com.aptana.ide.documentation.libraryname.sampleview.  This view added to 'Other' category.
            Error
            Category com.aptana.ide.documentation not found for view com.aptana.ide.documentation.jquery.visualjquery.  This view added to 'Other' category.
            Error
            Tue Jul 27 10:29:48 EDT 2010
