1. Re: Nikon D70s + Process 2010 + Luminance Noise Reduction + Adjustment Brush = blurry picture
Dorin Nicolaescu-Musteață Jul 21, 2010 12:48 AM (in response to BDLImagery)I have a couple of high ISO D70s files, but cannot reproduce.
It's believable, given there were reports of local adjustments affecting outer areas, such when brush affects exposure in highlights around the sun, or overexposing areas painted by post-crop vignette. But it's the first time when I hear about sharpening/NR issues with the local adjsutments.
Can you provide a raw file+xmp? (via YouSendit.com)
2. Re: Nikon D70s + Process 2010 + Luminance Noise Reduction + Adjustment Brush = blurry picture
BDLImagery Jul 21, 2010 6:37 AM (in response to Dorin Nicolaescu-Musteață)The NEF and xmp files are now available at http://drop.io/LR3BugAdjBrushNoise8736
In the current development settings, I added an adjustment brush to the ceiling with an exposure adjustment of +0.01 simply to demonstrate the issue. As soon as the adjustment is applied, bluriness can be seen and is most apparent in the faces but can also be seen on the wooden floor and everywhere else.
I also noticed that by setting the mask to show (O), ditthering can be seen in the mask even though it was applied with feather, flow and density all set to 100%.
Let me know what you think.
Bruno
3. Re: Nikon D70s + Process 2010 + Luminance Noise Reduction + Adjustment Brush = blurry picture
Dorin Nicolaescu-Musteață Jul 21, 2010 7:08 AM (in response to BDLImagery)Hell... yes!
The global NR gets amplified when only 0.1EV local exposure applied on a small patch.
I have reproduced it on a Canon file too.
A clear bug, nothing else to say.
4. Re: Nikon D70s + Process 2010 + Luminance Noise Reduction + Adjustment Brush = blurry picture
BDLImagery Jul 22, 2010 5:33 AM (in response to Dorin Nicolaescu-Musteață)I must make a correction to my post.
The dithering which I refered to when I added the local brush and revealed the mask is not an issue; I had not realized that Auto Mask was on and by turning it off and reapplying the mask, the brush covers the entire selection area without any dithering.
However, the issue of the overall blurring of the photo remains. I updated the xmp file at http://drop.io/LR3BugAdjBrushNoise8736
I submitted a bug report to Adobe.
Bruno
5. Re: Nikon D70s + Process 2010 + Luminance Noise Reduction + Adjustment Brush = blurry picture
Dorin Nicolaescu-Musteață Apr 28, 2011 5:11 AM (in response to BDLImagery)FYI, despite being listed as fixed in release notes
Applying the exposure adjustment brush to a high ISO image could have caused excessive noise reduction correction to the entire image
this bug is still partially present in 3.4 final. The luma noise reduction is now fine, but I can still see traces of excessive chroma noise reduction when the localized tools are used.
6. Re: Nikon D70s + Process 2010 + Luminance Noise Reduction + Adjustment Brush = blurry picture
+becs Apr 28, 2011 5:03 PM (in response to Dorin Nicolaescu-Musteață)Dorin,
We haven't been able to repro the problem you describe. Can you post a link to a file that demonstrates the problem, using a utility like yousendit?
Becky -
7. Re: Nikon D70s + Process 2010 + Luminance Noise Reduction + Adjustment Brush = blurry picture
Dorin Nicolaescu-Musteață Apr 28, 2011 11:58 PM (in response to +becs)https://www.yousendit.com/download/VnBwZ28rZDVOQnhFQlE9PQ
Try toggling the brush adjustments on and off, and watch for the red flower on the glass.
This might not be related to the NR bug, but rather to the older LR2 one -- "highlights blown by local adjustmets" -- I don't know. What I can see is that local adjustmets affect areas they should not.
