3 Replies Latest reply on Jul 21, 2010 12:24 AM by eboda_snaf
    JS: Item coordinates and sizes
    eboda_snaf Level 1
      I've tried using both visibleBounds and geometricBounds to get a item coordinates and size on page..
      it will give me a strange results such as10.6413765606047, -2.93075, 179.358623439395, 202.93075
      The item's actual coordinate on page is just x=0mm, y=20mm, W=200mm and H=150mm shown on the panel,
      how can i get the item's actual coordiante as of the panel's?
      can anyone please advise? Thanks alot!!
        • 1. Re: JS: Item coordinates and sizes
          Peter Kahrel Adobe Community Professional & MVP
          The script languages show measurements in credit-card number size decimals, that's ok.
          To check the reported bounds against what you see in the Transform panel, select the top-left anchor to check the first two values of the geometric bounds, the bottom-right one to check the last tw values of the bounds. Also bear in mind the Transform panel gives you x and y values of the selected anchor and the width and height of the frame whereas the geometricBounds gives you top, left, bottom, and right of a frame, so that you need to calculate the width and height.
          Peter
          • 2. Re: JS: Item coordinates and sizes
            PankChat Level 1
            Well what Peter has suggested is correct. You will getting the top, left,
            bottom, right coordinates of an object.
            I normally use to set my rulers to "mm" for better view or calculations
            for such purposes. Depends upon choice
            //Set the ruler option at zero point and change measurement units to mm
            var myDoc=app.activeDocument
            myDoc.zeroPoint = Array(0,0)
            with (myDoc.viewPreferences)
                    var myOldXUnits = horizontalMeasurementUnits;
                    var myOldYUnits = verticalMeasurementUnits;
                    horizontalMeasurementUnits = MeasurementUnits.millimeters;
                    verticalMeasurementUnits = MeasurementUnits.millimeters;
            Cheers.........
            • 3. Re: JS: Item coordinates and sizes
              eboda_snaf Level 1
              Thanks to both of u!!....
              cheers..
