2 Replies Latest reply on Jul 21, 2010 9:37 PM by UbuntuPenguin
    Flex setters are not getting Fired!
    NiladriSadhukhan Level 1
      I am facing a strange problem. In Flex, I have a VO(value Object) where I used couple of setter functions against some properties of that VO.
      This has one corresponding bean in java as well
      e,g
      Flex VO
      public
      var _bal:Number;
      public
      var actAm:String;
      public
      function set bal(_bal:Number):void{
      this.actAm = _bal.toFixed(2) + "";
      this._bal = _bal;
      JAVA Bean
      public double
      bal;
      public
      String actAm;
      //getters & setters
      Now this code was working fine till I was using java 1.4 and WAS 6. I am using BlazeDS for Flex-Java Communication. But now the java code has migrated to 1.5 and WAS 6.1 and I find that the actAm is becoming null at times. For 1st time loading of the screen the values are being
      pupulated but after saving the data without doing any data alteration, the value of actAm is becoming null.
      For the time being I fixed the same by setting the above code in Java setters. But is there any thing else like version mismatch or some coding flaw?
      Please revert if any one have any knoledge of the same.
      I was using :
      Flex sdk            : 3
      Flex Framework : Cairngorm
      BlazeDs
      Java Framework : Spring 1.2.6
      Java                  : 1.4
      WAS                 :  6.0
      I now am using :
      Flex sdk            : 3
      BlazeDs
      Java                 : 1.5
      WAS                 :  6.1
