5 Replies Latest reply on Jul 22, 2010 5:13 AM by rootsounds
    Problem Currency Formatting > 20 digit numbers
    NiladriSadhukhan
      Can any one suggest how to format currency for long numbers say 18 to 20 digits(decimal). I find Flex Number is not able to deal with such long amount formatting, so how to achieve the same in Flex.
        • 1. Re: Problem Currency Formatting > 20 digit numbers
          rootsounds Level 4
          Please share an example.
          • 2. Re: Problem Currency Formatting > 20 digit numbers
            NiladriSadhukhan Level 1
            Try below with say : 123456789012345.99
            <mx:Script>
                    <![CDATA[
                          import mx.events.ValidationResultEvent;
                          private var vResult:ValidationResultEvent;
                          // Event handler to validate and format input.
                          private function Format():void {
                                 vResult = numVal.validate();
                                if (vResult.type==ValidationResultEvent.VALID) {
                                    var temp:Number=Number(priceUS.text);
                                    formattedUSPrice.text= usdFormatter.format(temp);
                                else {
                                   formattedUSPrice.text="";
                </mx:Script>
                <mx:CurrencyFormatter id="usdFormatter" precision="2"
                    currencySymbol="$" decimalSeparatorFrom="." rounding="none"
                    decimalSeparatorTo="." useNegativeSign="true"
                    useThousandsSeparator="true" alignSymbol="left"/>
                <mx:NumberValidator id="numVal" source="{priceUS}" property="text"
                    allowNegative="true" domain="real"/>
                <mx:Panel title="CurrencyFormatter Example" width="75%" height="75%"
                    paddingTop="10" paddingLeft="10" paddingRight="10" paddingBottom="10">
                    <mx:Form width="100%">
                        <mx:FormItem label="Enter U.S. dollar amount:" width="100%">
                            <mx:TextInput id="priceUS" text="" width="50%"/>
                        </mx:FormItem>
                        <mx:FormItem label="Formatted amount: "  width="100%">
                            <mx:TextInput id="formattedUSPrice" text="" width="50%" />
                        </mx:FormItem>
                        <mx:FormItem>
                            <mx:Button label="Validate and Format" click="Format();"/>
                        </mx:FormItem>
                    </mx:Form>
            • 3. Re: Problem Currency Formatting > 20 digit numbers
              rootsounds Level 4
              I've confirmed from your example that it is rounding despite being instructed not to do so. It must be converting the field to a number before operating on it rather than just formatting a String.
              Since you have a number validator checking the input, all you need to do is strip out all non-numeric characters except for the decimal point. Then apply whatever formatting you like to the String through looping and fixed positions.
              • 4. Re: Problem Currency Formatting > 20 digit numbers
                Actually the root problem is something else. In my app I'v a form where user enters amount in number and on focus out I format it to display the same in currency string and on focus In I strip the string and convert it to Number. But I have to perform arithmetic operations on the number only.
                Now it looks like the Number datatype runs out of capacity for an amount say : 123456789012345.99.
                sample :
                var temp:Number= 123456789012345.99;
                Alert.show((temp+1)+'');
                actual result     : 123456789012346.99
                expected result : 123456789012346.98
                So how to deal with the looooong figures and how to process them !!
